Only teased so far, note that the company swore for years they would "never" create a streamer.
The fact they will means it will not be a copycat of stuff already out in the market, touted to be ground-breaking, multi functional, far more than just a normal streamer – we'll see...
But one thing for sure, the Schtreamer will stream CD music across a network, from any old cheap-as-chips standard USB data player, as in designed to work for PCs with any OS.
Seems that devices putting out USB Audio will NOT work, nor those like Shanling CR60 designed to facilitate ripping files from Audio CDs using their own firmware without a PC.
Apparently the Schtreamer requires a standard external ATAPI/CD-ROM block device, used for plain data transfer, arbitrary file types over USB.
Usually listed as " DVD±RW / CD-RW Combo Drive " but also
Optical Disc Drive
Multi-Drive / SuperMulti
Technically, unders the USB standards, a "Mass Storage Class (Interface Class 08h)" device using the SCSI transparent command set (Subclass 06h)
Now, these can be like $20, and paying more does not get you any "quality advantage" wrt use with the Schtreamer. Maybe reliability and longevity?
But I came across this post, about a group of not much more expensive examples that add features, greater functionality designed for when using for their OG purpose, as PC peripherals.
So, this thread can serve for discussing other examples – only units that meet the above requirements for use as a CD player feeding the Schiit Streamer please
AND for any info emerging about that device itself, as we learn more.
And yes it's my nickname, since the actual model name has yet to be revealed.
One tidbit - it will not support Roon, but apparently "will make Roon unnecessary"
? wut. ?!
Optical Disc Drive
? wut. ?!
