WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
See, I came across a lot of things like that but if you look closely at what it's trying to do, it takes 4 USB peripherals and shares them between two computers.
Ergo the switch takes the four ports and points them to one port or the other.
That won't work for hooking three sources up to one DAC.
I don't think any USB switch would work, because if I'm not mistaken, a regular USB switch allows for only one host, and the DAC is not it. You can have one computer as host and several DACs connected to such switch. The one you suggest is a USB KVM switch and that WOULD work for 2 sources to one DAC. The OP would need a USB KVM with 3 PC sources for it to work as he needs.
Yes, and might a manual switch, like the one on Amazon I linked to above, be better than a hub-like solution? It’s just switching the physical connections.
