I'm using the USB input to the DAC8 Pro with the normal windows drivers (not ASIO). I can get sound on windows applications but in REW I can't get sound - it says:
I'm also not getting any sound from games and some games even crash when attempting to change the audio settings. I'm guessing Windows normally resamples the audio but in this case it's not which is causing errors?
ASIO won't do for me at the moment since I use EqAPO for equalisation.
How would I be able to sort this?
Thanks
Code:
No input mixers available supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
Thanks
