USB Audio Interface for amateur SINAD measurements?
Dougey_Jones
Hi Everyone,
I'm sure this question has been answered/discussed elsewhere on ASR, but I'm failing at finding the right keywords to find the threads and information I'm looking for. A while back I saw a few mentions of fairly inexpensive chinese USB audio interfaces that had analog and balanced inputs/outputs as well as high SINAD (relatively) that would enable an amateur to conduct some bench testing at home as long as the component being tested didn't exceed the SINAD specs of the interface.
Can anybody point me in the right direction of these interfaces, and potentially any threads that discuss how to perform said testing?
Thank you!
What is your budget and what kinds of things do you want to measure?
REW is good free software for testing. A member pkane here has written another good free bit of testing software called Multitone.
Here is a thread about using it which will bring up some issues on gear used with it too. Long thread, probably best to skip to the last few pages as it has evolved considerably from the beginning.
Here is where pkane took an RME device, which is one of the best you can get for this kind of testing (except microphones), and tested it.
Here is where to download the software.
Another near state of the art device is the Cosmos ADC.
Here is where Amir measured one.
If you search for E1DA Cosmos you'll come up with multiple threads. The fellow behind this is a member here as well.
Like this one:
There is a scaler and buffer device for the Cosmos as well.
The Topping audio interface may be the one you were thinking of. Here is a review of it though I don't know of threads specifically about using it for measurements.
The Cosmos was definitely what I was thinking of. I'd really like to see what my Adcom GFP-750 can do in terms of SINAD in both passive and active modes. I've recently had it refreshed, including significant modifications and am very curious to see how it stacks up to more modern preamp's.
Stereophile reviewed it and measured it back in the day.
It was based upon a Nelson Pass design emphasizing circuit simplicity. Results are generally fine, but Pass wasn't going for super low distortion. The decade older GFP-565 was designed by Walt Jung known for working with op-amps and measured a bit better on distortion.
RME ADI-2/4 Pro SE or E1DA Cosmos ADCiso are currently the best for amateur use. Pros and Cons are always there. Post your measurement block diagram to get more accurate recommendations.
Since you want to measure amps you have to include some big resistors (as a load,depending what you want to measure) to your rig and possibly some voltage dividers if the DUT's voltage exceeds the one allowed by the interface.
