Roland68
There are no sound differences between USB 2.0 and 3.0. This has been tested extensively.Hello everyone,
I’m facing a strange issue with my audio setup and I’d appreciate your insights.
My system consists of:
Until recently, I was using a regular PC and the sound was excellent.
- Amplifier: Yamaha A-S501
- Speakers: Mission MX-3
- DAC: Topping E30 II Lite (separately powered)
- Source: PC running Windows 11, connected to the DAC via USB
I switched to a fanless industrial HTPC (no-name, wanted to get rid of noisy fans), but to my surprise the sound quality dropped noticeably. Music now feels compressed and lacking dynamics.
To troubleshoot, I tested with a laptop and the sound was again very good. The only difference I noticed:
When I tried the HTPC’s USB 3.0 port, the sound improved significantly, close to the original PC quality.
- On the PC/laptop I was using a USB 3.0 port
- On the HTPC I initially used a USB 2.0 port
I always thought it was completely irrelevant which device sends the signal via USB to the DAC, since USB is digital and the DAC is the one converting the digital signal into analog audio. So I’m a bit confused.
Has anyone else experienced such differences in audio quality depending on USB port version? Could this be related to bandwidth, power delivery, or something else in the USB implementation?
Thanks in advance for any advice or explanations!
If there is a difference, the problem lies with the source device or the cables. It's also well known that Windows computers have various background processes (sound cards, drivers, software, etc.) that can have an impact, as can contamination of the USB ports, although this should be rare nowadays.
The Topping E30 II Lite DAC, like almost all other HiFi DACs, always operates via USB 2.0, regardless of the port it's connected to. It makes no difference whether it's a USB 3.0 Type-A port or a USB 4.0 port with a USB-C connector; the transmission and protocol used are always USB 2.0.
To avoid problems with integrated circuits in the connectors, I generally recommend using genuine USB 2.0 cables for DACs, regardless of the connector type.
