[USA] Looking for system advice; nearfield bookshelf PC audio; budget ~$2-3k
SandSnip3r
I am finally moving into a home where I will have a dedicated office and am so excited to step up my audio game. I have spent a lot of time understanding which components are necessary given my particular constraints. First, let me outline my constraints/preferences:
  • A desktop PC will be my audio source
  • I want to be able to easily switch between headphone listening and speaker listening (I already have headphones, Beyerdynamic MMX 300 2nd gen)
  • My listening position is a sitting/standing office desk (have not yet purchased the desk)
  • My music preferences are a mix of electronic (progressive psytrance), rap, and rock (probably 70/15/15 respectively)
I do not yet have the experience to articulate the type of listening experience I am looking for (“warm” vs “accurate”, etc.). I plan to listen to music at a relatively low level for hours a day, so I do not want something fatiguing. But when I am jamming to a particular song, I’d love to crank it up and really feel it. I am a basshead and used to have a ported 15” SPL subwoofer in my car. I’m not necessarily trying to rattle the paintings off the wall at home, but I would like to feel the bass (and yet remain tight for higher BPM electronic music).
I have come up with a set of parts which fits what I need and I think will sound decent, but I’d like your advice on my choices. Some of my decisions might be stupid or maybe there are better components that will do what I want for a similar or lower price. It seems like the preference for an easy way to switch between headphones & speakers constrains me a bit. I have chosen passive speakers; I don’t have a good justification for why I’ve done this. Here’s what I’ve come up with:
  • DAC: Fiio K7
  • Amp: Fosi Audio ZA3
  • Speakers: Polk Audio Reserve R200
  • Subwoofer: SVS SB-1000 Pro
See my attached image for my connection setup, this is where some of the setup feels a bit convoluted and I am looking for input. My headphones and mic will connect to the Fiio K7. I will plug in RCA Y splitters to the K7’s preouts. One pair of RCAs will run down to the subwoofer. Another pair of RCAs will first run through a passive high-pass filter (probably 70hz) and then to the Fosi ZA3 amp. Of course, finally, speaker wire will run to the Polk R200 speakers. I have chosen the passive HPF to possibly reduce the burden of the low frequencies on the speakers. Maybe this is unnecessary and I can simply start by using the sub-out from the ZA3 for the subwoofer.
To be concise, I am looking for feedback mainly on my speaker choice, the HPF situation, and a general extra set of eyes on the whole setup to catch me from doing something dumb. Let’s say my overall budget is around $2-3k. Thank you!
Welcome to ASR!
I'd recommend going with a MiniDSP Flex* and a headphone amp instead of the Fiio K7 as DAC/headphone amp. The flexibility of the DSP can give you a lot more different ways to optimize your sound.
Note: * I prefer the Flex 8 personally. I can combine two pairs of single ended (RCA) outputs into 2 balanced outputs for the speaker amp, and still have 4 RCA outputs left for headphone amp and/or sub.
  • DAC: Fiio K7
I own a pair of r200, they're ok but I'd choose something different if I were you (I wouldn't buy them again, they now sit in a box since I've replaced them with Neumann's kh 150 which are far far superior).
They're pretty big and deep by the way, I don't see them fitting a desk.
My choice would be monitor speakers, Genelec or Neumann if you have that kind of money, Kali audio Adam audio or JBL if you don't.
The price/performance ratio is the best with these speakers, and it eliminates the need for an amplifier.
What's your budget?
Welcome to ASR!
Thanks for the welcome! The price of the MiniDSP Flex doesn't seem worth it to me. I'm not too picky about what drives my headphones at the moment. I understand the optionality that it enables though.
What's your budget?
Ah yeah, good point. I did notice the r200s are pretty large. Thanks. Why "monitor speakers"? It seems like they're focused on accurate reproduction, which I guess seems good. Genelec are usually powered, right? I'm not opposed to going this route. I figure my budget for the whole deal is $2-3k, not super firm on that though.
Does the regular rca flex not do the same thing?
With that budget you can get something really good and go Neumann or Genelec which have an amp, a dac and dsp (and automated room correction of premium quality) incorporated, you'll have a hard time beating that.
Yes they're designed for accurate reproduction, and that's exactly what everybody's looking for on this forum.
Personally I like the flexibility of having 8 channels to play with ... future options for full active cross-over, multiple subs, etc. The Flex HT (for USD$ 50 more) lose the Bluetooth, but gain eARC and can be used as a USB 8 channel DAC when connected to a computer, may be even better.
