Ah..... we will have to concentrate on saving other poor soulsWell.... I probably would have returned it anyway, as I never heard a difference through blind (or sighted) listening.
Looking at this photo, a few things stand out:
We need some severe looking outfits , I'm thinking knee high leather boots , well fitted trousers and shirts .. black, grey , red and white colour palette.Now you're just throwing wood on the 'ASR is a cult' bonfire
The heart of what makes our switch so unique is use of ACTIVE, HIGH-SPEED, LOW-JITTER DIFFERENTIAL DIGITAL ISOLATOR chips in conjunction with ULTRA-LOW JITTER DIFFERENTIAL RE-CLOCKING FLIP-FLOPS. No other Ethernet switch on the market does this. Implementing this architecture correctly is difficult and costly!
That's because ADI stupidly wasn't aware of how damaging to the texture and soul of the data their reference designs were. Hopefully they are now in touch and working with Uptone on the next revisions which I'm sure will sound much more sublime.The PCB layout around the LT3045 regulators looks nothing like that recommended by ADI.
So like a kinky kraftwerk?We need some severe looking outfits , I'm thinking knee high leather boots , well fitted trousers and shirts .. black, grey , red and white colour palette.
Some kind of bird as a insignia maybe perched on a soldering iron, oh leather caps can't have too much leather .
We want to be taken seriously, this will help.
Manchester encoding is used for 10 Mbps Ethernet. 100 Mbps uses NRZI coding similar to USB, and GbE uses PAM5. That's all on the twisted pair cabling. Inside a device, behind the PHY, other formats are used, usually GMII, RGMII, or SGMII. Presumably it is one of these formats that crosses their isolation barrier. Not that this makes any sense of their techobabble.From the product page:
Wow - total snakeoil - I wonder if the proprietors of 'Uptone Audio' have ever heard of Manchester Encoding, used by any old switch in existence.The heart of what makes our switch so unique is use of ACTIVE, HIGH-SPEED, LOW-JITTER DIFFERENTIAL DIGITAL ISOLATOR chips in conjunction with ULTRA-LOW JITTER DIFFERENTIAL RE-CLOCKING FLIP-FLOPS. No other Ethernet switch on the market does this. Implementing this architecture correctly is difficult and costly!
The layout person probably is the only down-to-earth guy in this company and decided to just get the job done rather than freaking out. He was handed a schematic, given a fixed PCB real estate and connector layout (as the casing tools already have been ordered after some eye-balling) and for sure he had a strict time-line with the boss looking over his shoulders from time to time, making subtle noises of restlessness... at least that's what I could easily imagine, been there, done that.Looking at this photo, a few things stand out:
1a. No attempt appears to have been made regarding trace length matching either within each differential pair or between the 4 pairs of each port. For a company constantly banging on about signal integrity, such sloppiness has no excuse, even if it works in practice.
1b. The diff pairs appear to have been routed as separate traces resulting in variable spacing. Again, no excuse not to get this right.
2a. The voltage regulators are all bunched together, far from the loads they are supplying. This distance likely defeats the low noise these devices are capable of (as if it mattered here).
2b. The PCB layout around the LT3045 regulators looks nothing like that recommended by ADI.
As a big fan of 80's Metal I couldn't agree more, but we need to ditch the totalitarian colors and replace them with studs, chains and maybe a bullet belt.
I would encourage anyone that's interested in this device to look at the objective measurements; that tells the whole story.
Eh ?? That's the whole point. There are none. Testing to see if an Ethernet switch can enhance the quality of the audio encoded into a digital stream being transported by TCP/IP over an Ethernet connection is like testing to see if a ball will rise or fall when I let go of it.I would encourage anyone that's interested in this device to look at the objective measurements; that tells the whole story.
The same way you their new measurement device isn't getting closer to release, it's really getting further from release.Wait until John Swenson designs his new measurement technology. It will clearly demonstrate that the ball is rising while you all think it’s falling.
A simple and extremely meaningful measurement test @amirm can conduct right now without this ether regen is to connect a dac to a PC connected to a very ordinary network switch, one we can assume must be deficient if we believe that the ether regen does something beneficial. Apply test signals and measure. Whilst measuring pull out the ethernet cable from the switch to the PC.
The test signal will continue to play because its buffered in the PC. If the network switch was causing any problem we will measure an improvement in the output signal from the DAC.
