Indeed.
This product is moronic. The slightest amount of critical thinking demonstrates it to be utterly useless.
My question is do they believe this product provides benefit, in which case they are technically incompetent, or are they selling a product they know to be ineffective in which case they are deliberately making false claims?
Sadly, they do believe it or at least they have convinced themselves and others that it's the end game. Then again when you're listening to the below and can't measure any equipment properly to backup all claims, anything is possible.
Posted April 26, 2018
Yes the Bazookas are the speakers in the new listening room. I have a Rythmik sub in there as well, which does a great job filling in the bottom octave.
A few years ago I swapped out the EX3s for PM2A silver voice coils with TICONAL magnets. These sound amazing.
I'm JUST getting the phono setup working right now so things are a little messed up right now, not a good time to take pictures. I actually got to listen to a few LPs last night!! (the digital stuff is shut down right now because I have all the LPS-1(.2)s in the lab for testing right now. Unfortunately I don't have separate "lab" and "listening" versions, so whenever I need to do tests I have to take the listening system apart.
After I get everything back together I'll take some pictures.
John S.
Posted April 27, 2018
The design is a bit unusual, there are actually two tubes, an 8" inner one and a 12" outer one. The driver back goes into the inner tube, which ends about 8" from the back of the outer tube. The driver "plate" is square, the open sections are the "port". The interior of both the central and outer tubes have damping material added in just the right amount to create a critically damped resonance. I ran impedance tests as I stuffed from which I could easily tell when it was at critical damping.
The acoustical design is based on Martin King's work, but he just uses a standard box with the port on the bottom. With this coaxial arrangement the sound coming from the port is symmetrical with the driver which I think gives much better imaging than the port being several feet from the driver.
John S.
https://audiophilestyle.com/forums/topic/30173-johns-life-changes/?do=findComment&comment=813894
