- Joined
- Dec 5, 2019
- Messages
- 3,843
- Likes
- 3,790
@Superdad
@ 39 minutes: No it's not apparent that 1500 sold means it obviously does something. 1500 people believing in Unicorns doesn't make Unicorns real.
@ 40.5 minutes: If John Swenson has a room chock full of measurement gear then why don't we have any published measurements?
@ 41 minutes: Some of do understand Manchester encoding and PAM. Yes and at 10GBe these interfaces are all incredibly tight jitter tolerance. Tolerances that you can't even come close to with your $640 box.
@ 44 minutes: As long as the the next hop can recover the data we are only concerned with the duration. 24/192 or DSD 128/256 has an incredibly short wire time. Fractions of a second.
@ 46 minutes: Signal integrity will degrade over the 328 foot distance, most PHY's are good for 380 feet. Most home installs probably deal in the 45-60 maximum foot range.
@ 47.5 minutes: Who cares if a bit of ground plane noise introduces some clock float. These Eye Pattern requirements have +/- threshold.
@ 49 minutes: If you have all these changes of current demand then why can't you put a test signal into a DAC, use common tools to generate all sorts of system load on various sub systems and show it in the DAC output! I invite you to blind test this on a system where I use iPerf to generate traffic while you listen.
@ 55 minutes. USB 2.0 is not faster than 1GBe Ethernet. As a matter of fact it's 50% of the speed.
@ 57 minutes: Where is John taking this leakage current measurement?
@ 101 minutes: I can stop leakage current with optical or wireless Ethernet. I did 10GBe fiber, that's switch, SFP+ LC SR modules, and network cards for $210, 33% of the cost of your eR and I get 3000% the throughput and 100% electrical isolation and tighter Jitter tolerances. Again where are the leakage current's measured?
@ 104 minutes: "I can show you graphs" please do and while you are at it show this at the output of the DAC.
@ 115 minutes: Why don't we just ground strap a power supply if this is all it takes to shunt that noise away from the powered device?
Congrats - you just put 10x more effort into that than they did into verifying the unit's usefulness.
