Veri
- Joined
- Feb 6, 2018
- Messages
- 9,598
- Likes
- 12,040
That the new 007 movie?Someone should revoke his licence to shill.
Bond goes undercover as an influencer?That the new 007 movie?
I'm glad I had the common sense to check other people's opinions on the ER before I went ahead with the purchase. Common sense actually works!
NETWORK EQUIPMENT IN DIGITAL AUDIO AND VIBRATION
Network switches in hi-fi systems - in this case the M12 SWITCH Magic - are very sensitive for vibration.
Most audiophiles do not realize that network switches, especially those in close proximity to the main hi-fi rig, should be treated with the same attention to vibration as any other high quality digital audio component. In fact, during our listening trials, we've found the impact of anti-vibration footers under the M12 SWITCH Magic to be greater than under a DAC.
This simple tweak, quite unexpectedly, boosted the performance to the sound quality level that was possible to achieve only with the ultimate network switch; M12 SWITCH GOLD.
You can't shake up the bits or like dice they roll a different number almost every time.Apparently adding audiophile isolation feet to a switch makes all the difference, guess @amirm should retest (not). Apparently the bits in an audio bitstream are much more sensitive than all that data bits that just work in networks all over the world...
My question is : do you have performed such a test with the EtherRegen?
My question in response is why does it take a 3rd party to produce data that the manufacturers should be doing?
Reading your stuff here: (1) thank you and (2) I became a member and donor immediately. Maybe you ok explain to me why I should be hearing a difference from those streamers.
Right. A buddy just ignored my advice to buy a $549 easy to use widely compatible streamer (a Pi can be done cheaper but he’s not a DIY guy) in favor of a - discounted - $2,500 difficult to use streamer with unnecessary features and hardware and very limited compatibility with streaming services. I think he cannot accept that “high end” sound does not require 1/4” faceplates and $2,000 plus price tags. I tried to explain that these are not anything more than computers focused on transmitting bit-perfect data according to the relevant standard, but I think my 9 month old Pug comprehends more of my lectures on the common misconceptions surrounding Special Relativity than my buddy did my quips about streamers.First of all, welcome!
Well, something could be broken of course... Other than that, your bullshit meter seems properly tuned.
Thank you very much for the kind donation. There is a technical explanation that the noise from the streamer could be travelling to the downstream DAC and pollute its analog output. In practice, hardly any DAC I have tested has such issues. And even if the problem was there, it would manifest itself as noise, not "soundstage, etc." that people describe as benefits of one vs another streamer.Reading your stuff here: (1) thank you and (2) I became a member and donor immediately. Maybe you ok explain to me why I should be hearing a difference from those streamers.
Welcome to ASR!Maybe you ok explain to me why I should be hearing a difference from those streamers.
I love that Sal!Welcome to ASR!
There is only one truthful answer to your question, because it makes LOTS of money for everyone involved in the high end industry. The print and web media along with the manufacturers have all joined together to brainwash the public into believing more $ buys better sound. I got my copy of TAS the other day promoting the glorious sound of the TecDAS Air Force Zero $450,000 US turntable. Yes you read that right, a almost half million dollars to drag a rock thru a ditch. OMG
Great line. And apt. Sort of reminds me of Bugatti. It's not exactly a good comparison, since the car at least does something amazing..., but where would you even drive it?...almost half million dollars to drag a rock thru a ditch.
Our brain on the other hand, is happy to manufacture such fidelity differences with ease even if technically nothing has changed.
I believe he was the one getting too tightly torqued.You will enjoy this: one of the makers of one of the most popular ultra high end streamers told a reviewer that he can hear differences in sound depending on how tight he torques the screws of the top plate of his streamer!!!!
That certainly ranks way up there with a guy I know that says the screws on his AC receptacles made a difference!You will enjoy this: one of the makers of one of the most popular ultra high end streamers told a reviewer that he can hear differences in sound depending on how tight he torques the screws of the top plate of his streamer!!!!
