Gunning for the joke of the week award?I'm sure @Superdad can clarify
The comma splice just kills me.
And precisely how has Alex concluded that sub 10 ps of jitter on a dac output is audible?Oh, the red herrings are flying:
Except that the funny thing is, while the Audio Precision Amir worships at is a very nice general purpose unit, it is not that well suited to measuring jitter in DACs. What’s that? Heresy! Yet if you look at the specifications for the ADC in the top-of-the-line APx555, you will see that its own jitter is 600 picoseconds! So that will swamp the jitter details of a device under test—which might be in the range of 10s of picoseconds--or ideally less.
And precisely how has Alex concluded that sub 10 ps of jitter on a dac clock is audible?
And then by definition eliminate it in the dac output.Am I missing something? I thought that this particular fraud was supposed to eliminate jitter in the ethernet connection?
The logical fallacy of this assertion beggers belief. It is either a fundamental lack of technical understanding on @Superdad Alex and Swensons behalf, or just marketing lies.
Yes sorry I changed itWell, your mention of the DAC clock (which is the important one, but unrelated to what this ripoff is supposed to "fix") triggered my reaction.
I have no doubt in my mind that the misrepresentations are knowing and deliberate. But I don't think anyone here would think any differently, so as Thomas said, not worth the keystrokes.
I think liars and fraudsters should be exposed. It also has a wider impact as people will read and some will decide to find out more and educate themselves on the subject.Well, your mention of the DAC clock (which is the important one, but unrelated to what this ripoff is supposed to "fix") triggered my reaction.
As Don noted, that is a spec for the digital input and output in the analyzer, not "ADC:"Oh, the red herrings are flying:
"Except that the funny thing is, while the Audio Precision Amir worships at is a very nice general purpose unit, it is not that well suited to measuring jitter in DACs. What’s that? Heresy! Yet if you look at the specifications for the ADC in the top-of-the-line APx555, you will see that its own jitter is 600 picoseconds! So that will swamp the jitter details of a device under test—which might be in the range of 10s of picoseconds--or ideally less."
There are three types of digital I/O on APx555: Unbalanced (S/PDIF), Balanced (AES/EBU) and Optical (Toslink). Above is giving the jitter specs for those.
I don't use any of the digital interfaces to measuring jitter. I use the analog output of the DAC which by definition goes into the ADC on the APx555. A spectrum analysis there will then show all jitter sources including the analyzer itself. Here is an example from a great DAC:
We see that the worse case spike is at -140 dB which is equivalent to the low order bit of a 24-bit PCM sample. 600 nanoseconds would create a spike that is at just -97 dB or a 16-bit audio sample. There is clearly no spike at -97 dB.
Bottom line, he (Alex or is it John?), confusing the brake for accelerator in a car and is claiming to be a race car driver. There is no such residual jitter in APx555 analyzer.
This is the problem folks. People supposedly writing papers about "jitter" don't understand what it really is, how it is measured, and how it manifests itself. They are running with Wikipedia definitions and inventing the rest.....
I made a typo. My computation was for 600 picoseconds. Corrected.Remember he was squawking at 600 picoseconds. I thought 0.6 ns and how that's no where near the thresh hold of audibility.
We see that the worse case spike is at -140 dB which is equivalent to the low order bit of a 24-bit PCM sample. 600 picoseconds would create a spike that is at just -97 dB or a 16-bit audio sample. There is clearly no spike at -97 dB.
$640 worth apparently.if there is X amount of noise on the gnd. plane, then what is the amount of jitter generated at the clock?
