UPGRADING FROM DROP+Grace DAC - B3 Professional XLR or TOPPING E50 ?
dreadknot
taylors ,sc
i plan a upgrade an replacement from my current DROP + Grace Design Standard DAC Balanced unit
my current two picks are the TOPPING E50 & B3 Professional XLR dac both are in my price budget of 200$
which would pair an work best with my linux pc
an my Schiit stax of
Schiit Lokius 6-Band Balanced Tone Control
Schiit Magnius Balanced Headphone Amp
(all xlr connectors used)
iv got some spare trrs 1/4 to xlr cables that i can use with the e50 if i went with it
which dac use the best to go with
Unless you have any malfunctioning issue or lack of feature with your current DAC which is a very well measured (audibly transparent) AKM-based design, I wonder why you want to upgrade. Maybe you need another DAC for a different use?
my current one has a malfunctioning issue in one ch is outputting far lower then the other & dac sometimes loses connect from the pc
this has been this way since past the 4months an iv had the dac for almost 5 years running near 24/7
so i need a new one , i like my two picks but want so 3rd party info an advice on which is the best decent pick.
The Blafili B3 DAC with balanced XLR outputs at $109 seems to be too good to be true. But alas, according to @Jeromeof's excellent review at Head-Fi, its USB support is limited to a 16/48 bitrate.
If you need a no-frills USB DAC with balanced outputs, then there are some choices:
  • SMSL D-6S (also w/ Bluetooth)
  • Topping D10 Balanced
  • Topping E50
  • Topping D50 iii (slightly above your budget, but you should be able to find a b-stock)
Anything would serve your use case well.
  • Topping E50
I realize I'm a little late to the party :). I just wanted to say the Blafili B3 is not to good to be true. This thing is excellent! Complete silence, no clicks, pops etc.
Nothing wrong with 16/48 for computer playback, after all it is cd quality and sounds darn good doing it. Bluetooth will give you higher and it sounds good. In fact it's hands down the best bluetooth sound I have heard from any bluetooth device. Having the balanced connections is just the cherry on top.
I really enjoy this device, it is a spectacular underrated hifi device. Nice to have in your audio setup arsenal. True little gem.
