Got a question in my inbox about a Yamaha A-S 1100, maybe you might enjoy it and be able to give your opinion as well.
Anyway, here is the question:
This was my answer:
Opinions?
Hi, I am asking you here because whenever I try to ask the question, people conclude I do not like my AS1100
Some audiophiles on my European forum sent me directly to costly Accuphase, which in my view is a great compliment to Yamaha
So, as a Yamaha connoisseur, what would you think would be the way (if any) to an audible upgrade, strictly as amplification ?!
I am a plug n play non-technical guy...
I am looking long term either to class A, or mono-blocks + preamp, any ideas ?
This was my answer:
You have correctly identified me, i am a Yamaha connoisseur, hope you enjoy my rather unaudiophile opinion:
I don't think you can get an audible "upgrade" (assuming your speakers aren't something exotic) to a A-S 1100. It's a neutral and competent pre-amp/power-amp combination. I even believe you could replace your A-S1100 with a A-S500/501 and not experience audible degradation in sound quality, in a blind test.
If you have very high sensitivity speakers you might hear a faint hiss during silence with the A-S1100, this could be solved with one of the Hypex or Purifi Class D power amps. These things have comically low THD+N. The hiss comes from the power amp section in the A-S1100, so it's theoretically worth it to hook up a Hypex amp to "pre out", thus not using the Yamaha power amp section.
I did that, and indeed, the hiss was reduced.
However, i didn't hear it while sitting on my sofa, only when putting my ear directly to the tweeter and set volume to full. So i sent the Hypex module back, it's not worth it to me.
So why do i then use a A-S1200 and not a cheaper A-S500/501? What can i say, i like the nice things. Nothing boosts a mans confidence than nice VU meter and over 25kg of metal in the rack.
I think your friends are "audiofools" for recommending Accuphase amps as an audible upgrade, and i would instead recommend to invest in speakers, room correction and room treatment. 2000€ in room treatment can make a real and obvious difference. 2000€ more in amplification? I don't think so.
Opinions?
