Upgrade time
Jimbob54
What do you guys think of this combo?
Dan Clark Aeon RT
Schiit Magnius
Schiit Modius
I wanted to keep it clean and handsome looking.
I think this is one of the rare occasions where I can say I hope you picked the xlr option on the Aeons.
HiFidFan
U.S.A
Great choices. I can't think of anything much cleaner than a Magnius/Modius stack.
SonicallyDeaF
SonicallyDeaF
Chicago, Illinois
Thanks for the response my fellow music lovers. However, don't you guys think that the Asgard 3 will make more sense because it will add more body to the cans of choice?
SonicallyDeaF
SonicallyDeaF
Chicago, Illinois
Thank you for the response. I have not set the purchase yet as I am doing more investigation and research with this combo. I have a knowledge on how all these will sound like, but is that the sound that I will translate in reality to me???
VMAT4
South Central Pennsylvania
While everyone so far has congratulated you on your choice of headphones and electronics. I have to ask Aeon RT or Aeon Noire? Is the extra $400 worth it?
VMAT4
It's the Aeon RT, what is the extra 400 bucks? I'm confused.
Have you considered the Noire? And is the Noire worth the extra $400 as we have Amir's Equalization curve?
Beershaun
The Asgard 3 measured terrible/bottom quartile 87db SINAD. Compared to the Modius and Magnius it's not even a debate. Seems like you should stick with your original plan that everyone agreed with you on.
https://www.audiosciencereview.com/forum/index.php?threads/schiit-asgard-3-headphone-amp-dac.14393/
Modius 115db/top quartile
https://www.audiosciencereview.com/forum/index.php?threads/schiit-modius-balanced-dac-review.13769/
Magnius 119db with XLR/top quartile. And +1 to @Jimbob54 on getting the XLR headphones the Magnius measured significantly better with XLR than RCA.
https://www.audiosciencereview.com/...-magnius-balanced-headphone-amp-review.15252/
threni
/dev/null
SonicallyDeaF
SonicallyDeaF
Chicago, Illinois
Ah, I see. Whilst the advert for that particular headphone seems tempting and I quote "ÆON 2 Noire's tuning almost exactly aligns to the “Harman Curve,” gently boosting bass and treble compared to ÆON 2 Closed. The result is a “lighter” sounding midrange and a soundstage that moves the “stage” a bit further from the listener for a wider and deeper space". I do not think the extra 400 buckaroos is worth it. First is define "lighter" sounding midrange - don't know if they mean musically thin, if so, then no go. Second is "moves the "stage" a bit further", how a bit further??? If on the Aeon 2 is about let's say 2 inches away then a bit further is 2.5 inches??? Seems like a marketing strategy to me.
VMAT4
Amir's EQ Curve brings the RT closer to the Harmon Curve. So, maybe you can experiment and see for yourself when new 'phones arrive. Right now I wish I had the money to invest in such 'phones.
HiFidFan
U.S.A
The Asgard 3 didn't measure poorly, just the internal (optional) DAC. With another DAC (Modius, Topping E30 etc) it'd be fine.
If you're going to add the Modius to either, what is the benefit of Asgard 3 over Magnius?
SonicallyDeaF
SonicallyDeaF
Chicago, Illinois
Oh no, I have not purchased the headphones yet. I am still in the investigating process. No purchase have been made yet.
SonicallyDeaF
SonicallyDeaF
Chicago, Illinois
So, if the amp measured poorly - is it already a no go? Please correct me if I am wrong, but from my understanding between the Modius and Asgard 3, the Modius has a more of a wall sound whereas the Asgard 3 has fullness and body.
Beershaun
Ok. The dac measured poorly and the amplifier measured worse than the magnius. So still the same conclusion to skip the asgard in favor of his original plan.
