Hi there - is there a way to get a significant & noticeable improvement in sound quality by adding a component to this set up? I currently use a Sonos Connect and plug the analog RCA output into a Niles si2100 power amp driving a set of Elac DBR62. I exclusively listen to spotify at max quality (no ripped cd's or anything else). I actually think it sounds great, but honestly am wondering if I am missing out and can make it even better (potential rabbit hole I know).
Which one of the below options do you think would make a SIGNIFICANT & NOTICEABLE difference (i am not a audiophile).
1) If i put an external DAC between the Sonos Connect and the Niles Power amp
2) Put a pre-amp with built in DAC between Sonos Connect and Niles Power Amp
3) Get a new integrated Amp to replace the Niles (maybe one of the Emotivas)
4) Ignore all the above as a unnecessary rabbit hole and go back to listening to music.
FYI - I also tried Amazon HD but could not notice any difference in sound quality. So I don't believe switching away from Spotify to Tidal/Quboz is worthwhile for me.
My room positioning of the speakers is not perfect but it's good enough given other constraints (i.e. far enough away from walls, and i sit in a slightly elongated triangle)
