Upgrade from R3
simplywyn
I'm currently running R3's on my desk as desktop speakers, and I love the idea of huge audiophile speakers on the desk as I work. Is there a next level version of this? I know R3 metas are out but I feel like that's a side grade, and not really an upgrade.
Anyone with some ideas about what's after R3?
What's your budget? Have you optimized what you already own (treatment, DSP, maybe some augment like BACCH)?
Genelec Ones?
One of the Ascilab Purifi models?
You did not write any budget. The upgrade that comes to mind could well be KEF Q11 Meta unless you have some specifications that exclude floorstanders. I mean, you could maybe put them next to your desk. (I have my own speakers on stands right next to the desk.) The justification for this recommendation is: Spinorama score of Q11 Meta is better, there will be more bass capability. Hopefully you can get room mode PEQ corrections also going somehow to reduce bass booming effects.
Even so, my expectation is that your upgrade is quite small and I do not honestly think it is worth doing. If you have speaker as good as R3 is, there is relatively little left to discover. You can get more bass and that's about it.
The OP does mention that the speakers will be put on the desk, to be fair. But yes, a bit more detail on the budget and requirements would be helpful.
Hmm a simple google would tell you the reference series
What's the difference? Reference just looks more expensive.
I have R11. My budget, well between 2-5k for an upgrade potentially. Desk top only (like bookshelf speakers like the R3)
Is there anything out there that comes to mind?
Well it is expensive!
Comparing the Q, R and Reference series, the cabinet construction quality and driver quality should increase as you go up the through the ranges.
In the measurements this is, in theory, revealed by the distortion specs.
HARMONIC DISTORTION (90dB, 1m)
Q Concerto Meta: <1% 91 Hz - 20 kHz
R3 Meta: <0.5% 90 Hz - 20 kHz
Reference 1 Meta: <0.5% 40Hz – 100kHz
So the R3 Meta and Reference 1 Meta have lower distortion than the Q Concerto Meta.
...and the Reference 1 Meta can keep the same distortion level down to lower frequencies than the R3 Meta.
Edit:
Also, if you look at the frequency response flatness metric on Spinorama...
Q Concerto Meta: +/-2.5dB
R3 Meta: +/-2.1dB
Reference 1 Meta: +/-1.8dB
Edit:
R3 Meta: +/-2.1dB
Is there no speaker with these features that don’t cost ridiculous amounts of money?
Cheap?
The reference are $12000 whereas I got my r3 for $2500
Are we in marginal gain land now?
Usually top of the line range of speakers seems to have a much larger markup, be it due to "Made in UK" or what have you.
I would think the Genelec 8331a is an upgrade for $4500, no? e.g.: GLM, 3 way, digital AES/BEU.
With 5k budget I'd wait for the fancy Ascilabs
(C6C/C5C for cardioïd, S6B for Purifi goodness)
Sure. But the R3 already is a 3-way with good dispersion, and a good measurement setup with MiniDSP (if needed) should be ~1k tops.
Except it's their money and they asked for an upgrade
Nah, upgrade as in, if there is a worth. Not just wasting money.
Everything is going to be diminishing returns.
Can't get away from that.
Nothing is going to beat the value of the r3, otherwise you wouldn't have purchased it in the first place in that price range.
