staticV3
- Joined
- Aug 29, 2019
- Messages
- 10,232
- Likes
- 16,511
Looks goodCould I use this cable, StaticV3?
16 cores, but only silver.Looks good
Good idea, but there is no adapter to the Arya. It comes with 6.3 mm.I would recommend that you wait which cable comes with your new headphone. If the cable has a 3.5mm source connector (qudelix side) then you can try it with your qudelix.
If it plays loud enough there is no need to buy a 2.5 mm cable.
In one of your posts you said the Hifiman headphone cables are crap. But if you buy another cable the sound will not improve, only the look, feel and haptic will change.
Easily solved with a cheap 6.3 to 3.5mm adapter.Good idea, but there is no adapter to the Arya. It comes with 6.3 mm.
Or even better, just move this cable onto your AryaThe picture is from this site:
About TRRS | Schiit Audio
www.schiit.com
Attached picture of my "Sundara cable".
Then why not buy the balanced cable instead?Easily solved with a cheap 6.3 to 3.5mm adapter.
See my other post just afterThen why not buy the balanced cable instead?
I do not see the point, besides the price difference.
I am going to sell my Sundara and but a nice pair of close-back headphones instead.Or even better, just move this cable onto your Arya
Yes, but to test if the Q5K can drive your arya from 3.5mm.....I am going to sell my Sundara and but a nice pair of close-back headphones instead.
I do not need to have two pairs of open-back headphones.
Good idea.Yes, but to test if the Q5K can drive your arya from 3.5mm.....
Do you have any good recommendation regarding close-back headphone?I am going to sell my Sundara and but a nice pair of close-back headphones instead.
You have the Arya and the q5k dont you? Press play and tell us?Good idea.
Maybe at stupid question, but who do I if Q5K 3.5 can drive min new Arya Stealth?
Ha, that's a good one!You have the Arya and the q5k dont you? Press play and tell us?
Why?Ha, that's a good one!
And another... GEEKRIA 2.5mm Balanced Cable Compatible with HIFIMAN SUSVARA UNVEILED, SUNDARA, HE4XX, 400i, HE1000V2, Denon AH-D600, AH-D7200, 5N OCC Braided Silver Plated Audio Cord (2.5mm to Dual 3.5mm/4.9ft) https://amzn.eu/d/06vObBDwHere another example (2.5mm on source side, dual 3.5mm on headphone side)
Tripowin GranVia-Ersatzkabel
different colors are available
Don't know how much money you want to spend for extra cables. Don't expect any sound improvement.
It's because the Quidelix 5K has been measured here on ASR & it measures well, so that means it will be transparent to your ears (you'll just get unadulterated music as far as the amp is concerned, it won't be coloured in any way) - so that just leaves "does it get loud enough" on the table for you to discover when you listen with you headphone of choice. So it's easy for you to make that assessment, you just plug it in and play - that's why what Jimbob said was funny when you asked if the Quidelix 5K could drive this headphone that you own when you already simply own both already & just need to plug it in and listen & indeed tell us the answer.Why?
I am newbie to this world and needed to know what to listen for .
Please let me know what that is a good one?
What is your point here?
okIt's because the Quidelix 5K has been measured here on ASR & it measures well, so that means it will be transparent to your ears (you'll just get unadulterated music as far as the amp is concerned, it won't be coloured in any way) - so that just leaves "does it get loud enough" on the table for you to discover when you listen with you headphone of choice. So it's easy for you to make that assessment, you just plug it in and play - that's why what Jimbob said was funny when you asked if the Quidelix 5K could drive this headphone that you own when you already simply own both already & just need to plug it in and listen & indeed tell us the answer.
