Hi Folks
First I'd like to mention I'm in a pretty happy place right now with my audio setup:
Playing Amazon Music HD on MacBook with Motu M2 connected by XLR to KRK 10s subwoofer and Rokit 8 G2 powered studio monitors and RCA to Magni Heresy. Using a modest set of headphones - Sennheiser HD58x, Hifiman HE-400i, Beyerdynamic DT770 Pro 80ohm, Koss KPH30i, 1More Triple Driver. Motu M2 can drive perfectly fine all headphones except Hifiman HE-400i and 1More Triple Driver for which I use the Heresy.
I have no issues or complaints with my audio quality other than the inconvenience of having to max the volume of my Motu M2 when using Heresy and risking a loud blast from my studio monitors if I forget to dial the volume down before turning them on later.
As many of us here I got badly bitten by the upgrade bug and began my audiofool quest to find ways to improve my equipment with the goal of making it more convenient and enjoyable to listen to music. I do spend my whole day listening to music while working from home so I can easily justify spending $1000+ on equipment if I'm sure it will actually lead to quantifiable improvements in my music listening experience.
I know there are multiple ways I can spend $$$ to improve my audio roughly boiling down to: new studio monitors, new headphones, new DAC/amp. I know my studio monitors are old and not well rated, but they sound well and I like them - the bass response with the KRK 10s is just awesome. I recently got my HD58x and the Heresy amp which "unlocked" the HE-400i to its potential and don't feel like getting even more cans at this point.
I have a significant uneasiness about Motu M2's DAC even though from all accounts it is supposed to be one of the better DACs on a budget USB audio interface at the moment. I'm also familiar with the common opinion that all DACs sound the same and I agree to some extent. I got a simple A/B switcher, wrote some scripts and did a few level-matched A/B tests:
- I could not tell the difference between the sound of Motu M2 and the Apple USB-C to 3.5mm adapter.
- When comparing Motu M2 and my very old PreSonus AudioBox USB interface though I could tell them apart every single time. The differences were subtle but profound - the timbre of vocals was so much better on the Motu M2 that it sounds "passionate" vs "flat" on the Presonus AudioBox and the music sounded overall more "mellow" on Motu vs "harsh" on Presonus.
To clarify - I did the Motu M2 vs PreSonus comparison in a blind A/B test - level-matched to 1dB using an app on my phone (I know not perfect). I wrote a script to switch to a random interface and a script to switch to the next one. Switching to a random one at first with a few switches to the next one I was able to identify which one was which by comparing the "harshness" of the sound and the "passion" of the vocals. If someone is interested in the scripts I can publish them, they are very simple and work for MacOS.
These A/B tests led me to a believe that DACs might indeed sound the same if they are in the same generation/class, but DAC tech advanced so much lately that I can't make this conclusion universally. What about current higher class mid-fi DACs though - would they be such a significant improvement over Motu M2 as it was over PreSonus AudioBox?
The current most hyped mid-fi DAC with the best measurements is Topping D90 and paired with Topping A90 amp I would get a fully balanced stack that would be very convenient to use with both headphones and studio monitors. Will it have any difference in the sound quality though? I would hate to "upgrade" to only realize that everything sounds the same.
What do you folks think? Has anyone made the jump from low-tier DAC comparable to Motu M2 to a mid-tier one like D90 and ideally done an A/B test between them - do they improve the sound in a discernible and appreciable way?
I would also appreciate any opinions about other ways to improve my setup. Upgrade bug-squashing comments would be appreciated too!
Thank you!
Thank you!
