Updated Digital Audio Sampling vs. Perceived Quality OCT 15, 2022
Jim Shaw
North central USA
The views of Hans Beekhuyzen are an acquired taste. But for those here wishing to hear yet another short discussion on this topic, you could do worse than this new post.
I know that a little bit of arithmetic can be antithetical to just listening. But Hans provides some explanations of why (or why not) higher resolution digital audio may sound better. Of course, as with all things Beekhuyzen, you might have to pay some attention and think a little. And Hans paints with a broad brush. But understanding digital audio can be worth the effort. You may be paying a lot of money for numbers you don't understand.
antcollinet
UK/Cheshire
A lovely evidence free statement - "Less steep filters sound better"
Not to mention "only high end dacs can upsample properly"
voodooless
Netherlands
“The immoral factor, selling something else than promised”
:facepalm:
Really? Now that is a problem? It never is with all the other nonsense he spouts.
He thinks bit depth is only about dynamic range. He also thinks CD masters are recorded at 44.1 kHz?
Once again a load of nonsense, no proof, no controlled test, not even an explanation of the core “issue”.
Jim Shaw
Jim Shaw
North central USA
:facepalm:
Master tapes can be any of many sample rates for sure. But if a CD master is recorded at anything other than 44.1kHz, it won't play on a Red Book (common, standardized) player, will it?!
Will it?
voodooless
Netherlands
Will it?
Recording != mastering. A CD master is not recorded, is it? it's just a 16/44.1 audio file created by a DAW mixed from recordings that are most likely done at least 96 kHz.
Blumlein 88
Most commercial music, most being like 90% probably more are still done at 44.1 khz or 48 khz depending upon whether it is for music only or video use. Nearly any DAW will upsample to apply various processing and then downsample the result back to the base sample rate. So most likely a CD is from a 44.1 khz recording. With usually many, many effects applied between recording and releasing a CD.
xnor
When talking about filter steepness he's making a fatal mistake:
He's comparing the steepness of crossover filters that operate well within the audible range with brickwall filters that operates above 20 kHz. It's easy to design brickwall filters that have virtually zero effect in the audible frequency range, given a sampling rate of 44.1 kHz or higher.
In other words: pass a bandlimited (e.g. < 20 kHz) signal through such a filter and it will be output unaltered except for a small delay.
He would have a valid point if he was talking about a sampling rate of e.g. 16 kHz.
Also, why is he calling low-pass filters low-shelf filters?
xnor
Of course he also censors his comment section or at the very least has blocked me. I guess that's how you protect your flock from those pesky facts that contradict your false claims and opinions.
Going through the comment section, you can see so many people that have been mislead by his misinformation. For example, I've read multiple times that people referred to one of his "facts" from an earlier video where he asserted that sampling rate dictates "temporal resolution" - an audiophile myth born out of ignorance about digital audio fundamentals that has been debunked countless times over past decades. Apparently, that was one of his main points against 44.1 kHz, because "1/44.1 kHz = 22.7us, but human hearing has higher temporal resolution than that". :facepalm:
Sigh. It's so disappointing to witness.
voodooless
Netherlands
Funny how he brings none of this up this time. It’s as if he reads ASR and knows he’s wrong now… If so, it shows this forum is effective.
xnor
I don't think this has anything to do with ASR. As far as I can remember I have commented on some of his videos years ago and explained why he's factually wrong.
I guess, over the years, other people have told him the same so he finally dropped at least that one false claim. Silently, of course, because admitting to being ignorant and misleading people would be the honest thing to do.
I think you're blocked. I see a comments section.
Me too. But my comments are visible only to myself.
fieldcar
Milwaukee, Wisconsin, USA
Oh, so you never get a thumbs up or replies? I had that happen on Oluv's gadgets. He didn't like me cutting into his revenue stream by suggesting free and open source alternatives to his patreon top-tier paywalled EQ presets for his earfun buds.
Jim Shaw
Jim Shaw
North central USA
Apparently, that was one of his main points against 44.1 kHz, because 1/44.1 kHz = 22.7us, but human hearing has higher temporal resolution than that.
I could do with some peer reviewed references to verify this...
xnor
The argument is wrong anyway since sampling rate does not determine temporal resolution but bandwidth.
As I said, this comes from a complete ignorance of digital audio and signal processing fundamentals. These people think that digital audio is about connecting dots in straight lines, that samples have a temporal extent, that there are gaps between samples where information is lost, that there is an error if the sampling process doesn't match the signal peaks, and so on..
Jim Shaw
Jim Shaw
North central USA
voodooless
Netherlands
The part of your post that I copied in my reply question. Go back and look.
I didn’t post it ;) but in any case, it contains two claims:
1. Temporal resolution of 44.1 kHz sampled audio is 22.7 uSec
2. The human hearing has higher than 22.7 uSec temporal resolution.
Therefor I ask: for which one would you like a peer reviewed reference.
Jim Shaw
Jim Shaw
North central USA
The second one.
