- Joined
- May 15, 2019
- Messages
- 1,100
- Likes
- 4,645
The specification is an incredible 140dB, although there is no information on load resistance, frequency, or direction.
Even in the best case scenario (e.g., no load, around 1kHz, optimal direction) I doubt this value.
Correct. 140 dB must be some theoretical data sheet stuff, not the real world Crosstalk of the completed dongle with phones connected, its unbalanced design makes this impossible.. But - just checked with not optimal cabling and 100 kOhm load: already -110 dB. My only adapter for this kind of cabling just broke, so I will redo that later.
With a maximum output of 2.5V RMS, 140dB lower would result in 0.25µV RMS. That's below the noise of this device, which should be around 1µV.
Can a sine be measured if it actually disappears into noise?
Easy peasy, and you see it here all the time - FFT.
Even for devices with balanced outputs, I've never read a value of 140dB for crosstalk.
With unbalanced outputs, 120dB might be possible.
But 140dB? Isn't that probably a typo?
Is possible. See here, measured at the XLR outputs.
RME ADI-2/4 Pro SE - Auto-measured with Multitone
Ok, I came across an oddity. Although I hadn't set the zoom levels properly when saving results, I did notice that the Linearity result for my motherboard from the test plan seemed really good. So I repeated it as a single test (I set averages to 32, same as the test plan, if that means...
www.audiosciencereview.com
