Anticipate yes. Be sure, noanticipate
Dual dac/ dual opamp, like Alpha XI1 or KA15 are REALLY nice and strong devices, sounding great with nice voltage and current even for low impedances.
Crosstalk is dictated from the quality of the ground connection from TRS female plug to internals of the USB-A connector. That value will change with cables plugged in, both by the basic design of the cable and the contact resistance of the TRS male jack. So whatever me or anyone else measures has no meaning for your personal setup.
My sample's output impedance is 0.57 to 0.58 ohm. I measured both channels using 100 Hz and 1 kHz tones. Used just a simple method with a true rms meter.More interesting is the output impedance. I measured 0.544 Ohm on left output channel, 0.531 Ohm on right output channel.
1 kHz sine tone SINAD results at its maximum unloaded output have been added to the review. In fact, I made these measurements originally but did not include them for simplicity.Could you please provide results also for maximum line level output (2.5V)?
www.audiosciencereview.com
jkim many thanks for those measurements - in particular - frequency/phase, IMD/level and THDN/frequency/load.Looking at its frequency / phase response, it seems that the default filter is the minimum-phase type:Response at 96kHz sampling frequency:
As expected the phase does not shift much in the audible band when the bandwidth is increased. If you're concerned about the phase shift, use a wide bandwidth setting.
SMPTE IMD vs. output voltage under 300 Ohm load:
THD+N vs. frequency is excellent, too:
It works fine without apps. It'll obey the volume buttons like any other headphone or audio device you might plug in the tablet. But UAPP has some tricks up it's sleeve like matching the dongle sample rate and bit depth to the music format (so as to not have to do conversion inside Android) and hardware volume control and it works with Tidal, so you might like it.Just bought one on AliExpress for $27 with taxes. Unreal. I will use this on my Samsung Galaxy Tablet S8+. So is volume handled by the Samsung via its volume control or do I have to install a player?
I will use with Tidal.
EDIT: remember to turn the volume to zero and carefully increase it when you have your headphoney things on. Guess how I heard the loudest sound of my life?
I this kind of design is utterly insulting and I will never buy anything that behaves like this. @amirm should implement a standard test for this kind of characteristic. I strongly suspect that this logic, while always running, will affect music in certain situations - I wonder how....Does this cause some unwanted audible effects?
It's possible to understand why you might want to avoid a device that does this, but it's not possible to understand why it should be insulting.I this kind of design is utterly insulting and I will never buy anything that behaves like this. @amirm should implement a standard test for this kind of characteristic. I strongly suspect that this logic, while always running, will affect music in certain situations - I wonder how....
Thanks for this information. It's crucial for me.My first test was ramp-up issue on a Windows PC (as before with DS2) - none. I also did not hear any short noise on playback start (as reported for the non Max version). I used the already installed Bravo-HD ASIO drivers, but now I also see 'WASAPI headphone (CS43131+SGM826 HIFI Audio)' and that one works as well.
No you didn't, Wolf whose obsessed with chasing that tale down and in the end did but you won't like L&P pricing. For me simple - 2 dB to CS amp stage solves the problem on less than optimal implementations (it's really about fast optimal rail switching for H op mode in CS43131 case). For 25$ and +6 dB of output unbalanced this will remain to be taught to beat for a long time and it keeps it up very good under sensitive IEM's (12~16 Ohms load under 50 mV). To some extent even older CS DAC IP's had a same problem (like one's in Creative SB Z range digital clipping). Don't know why I ended up surrounded with CS DAC's especially on the go. I really regret Ivan never hooked up as we would by now had 120 dB (balanced, 117~118 unbalanced) pocket one's at much better prices (than L&P most definitely).I found an interesting phenomenon about this device. I believe this occurs with any DAC built on CS43131 (or CS43198).
As discussed by @staticV3 and @amirm in the review of SMSL DL100 (see the thread from this post), CS43131 adopts a technique that increases dynamic range (DNR). Basically, it reduces analog gain when it meets with low-level signals and compensates for the decreased signal by applying digital gain. This way noise is reduced but the signal level is preserved. But information on precisely how it is implemented is not documented. Based on the data I observed for the JM20 Max---the only CS43131-based device that I own---, it seems that the way this DNR enhancement function is turned on is different from the way it is turned off.
Shown below are the rms noise level measurements from two separate 1 kHz sinusoid sweeps. The first sweep was from -120 dB to 0 dB, which is how this test is usually done, and the second swept from 0 dB to -120 dB (i.e., loud to soft levels):
When the signal starts from a low level (-120 dB in this case), the DNR enhancement is turned on. Once it's on, the amount of noise reduction appears to be in its full state when the signal is lower than -40 dB, but above that level, noise reduction adapts to the signal, which seems to occur between -40 to -12 dB. In contrast, when the signal starts from a loud level, the function is turned off and responds to signal amplitude just like a brick wall. Noise reduction is turned on to its full state as soon as the signal reaches -51 dB.
More generally in music/audio playback, my guess is that whenever the signal goes below -50 dB in a certain time window, the DNR enhancement is turned on to its full state. But once it is turned on, going back to the off state does not occur by applying a single threshold, but rather signal-dependent, fine adjustment of analog/digital gain structure is made.
It has also been found that the DAC chip's digital compensation for analog gain reduction is not 100% accurate, which results in less than perfect linearity. See below for the measurements of linearity calculated from the above two sweeps:
Does this cause some unwanted audible effects? I doubt it. Just an interesting observation.
The specification is an incredible 140dB, although there is no information on load resistance, frequency, or direction.For the Jcally JM20 Max I measured crosstalk of around -73 dB, no matter what frequency.
Because it's performance trickery i.e. not real figures. Not that it matters SQ wise (probably..) but I hate to be deliberately fooled...not possible to understand why it should be insulting.
