tmtomh
- Joined
- Aug 14, 2018
- Messages
- 3,495
- Likes
- 10,562
If the device is humming in one location and not another, then the most likely scenario is that something in the power supply or other circuitry is reacting in some way to the AC feed - or less likely to DC offset from some other source, or even less likely from some other interference or phenomenon - in the OP's location.
DC blockers don't always eliminate DC-induced transformer hum from the AC line, but to my knowledge they almost always reduce it, at least somewhat, if that is indeed the cause.
So in this case I would hypothesize that the cause is not excessive DC in the OP's AC line. But as @solderdude notes, some transformers just hum. I don't know how plausible this is, but perhaps this transformer has become particularly susceptible to DC as it has aged, and perhaps the OP's AC, while within normal parameters, has just a bit more DC offset than in the other location where the device did not exhibit this hum.
Since the device is not just an amp, I'm also wondering if there's a possibility that the mechanical hum might be from some component other than the transformer itself. I had a MiniDSP SHD whose power supply hummed at a low level, albeit at a higher frequency/pitch than an amp transformer typically would. Listening closely with my ear near the top vents of the case, it became clear to me that it was not transformer hum - it was coil whine. They sent me a replacement PSU - a drop-in replacement but clearly a different revision with some different board components and locations - and that one did not exhibit the issue.
I never had the opportunity to test that unit anywhere but my own home, so I don't know if it would have disappeared when plugged into someone else's power. Still, I wonder if there's any possibility that coil whine could be what the OP is hearing?
