Class D amplifiers can last between 10 to 15 years with proper care, and some well-designed models are expected to last 20 years or more. The longevity of a Class D amplifier largely depends on the quality of its design and components, with high-end models from reputable manufacturers like NAD or those using ICs such as Hypex or Icepower showing strong reliability. Modern Class D amplifiers, especially those used in professional settings like jukeboxes, have demonstrated durability with continuous operation for over a decade.
While some users report concerns about reliability, particularly with lower-priced models, the failure rate is often linked to power supply issues rather than the Class D topology itself. In fact, Class D amplifiers are generally more reliable than their Class A/B counterparts in terms of thermal stress, as they do not experience significant thermal cycling when turned on and off, which can degrade components over time. However, capacitors—common to all solid-state amplifiers—can degrade over many years and may need replacement, though they are relatively inexpensive and easy to replace.
There is no inherent reason for Class D amplifiers to self-destruct or fail prematurely due to their switching operation, despite myths suggesting otherwise. The idea that the high-frequency switching causes wear is not supported by engineering evidence. Overall, a well-designed Class D amplifier, especially one with robust power supply and quality components, can be expected to last for decades, similar to high-quality Class A/B amplifiers.
