Unison Research Unico CDP Review
horias2000
Cluj-Napoca, Romania
Hello all,
This is a review and measurements of the Unico CDP CD Player from Unison Research (version with one tube). The company is from Italy and I'm not sure if they still exist or not. As with most of the units I get to measure, this came in as defective. The drive was not reading discs.
The unit is rather simple without any extra features. One of the main advertising point of these units was that it had a vacuum tube output buffer. The back of the unit is even simpler and I didn't consider it worth photographing. It has a mains input connector, the analog outputs and a COAX digital output. I was not able to use the later and I'm not sure why. Another "special" feature of these units is that it does not use a "classic" laser unit from Philips, Sony, etc. Instead, it uses a Teac CD-ROM unit with IDE interface. Yes, you read it right. It has a 5.25 inch CD-ROM unit made by Teac (52X if it matters :) ). This is an older (2002) IDE unit.
The problem with the drive was that it wasn't able to fully load the disc. There was a lot of dust and debris in the mechanical part of the tray and the belt was also worn. After a thorough cleaning and lubing and with the help of a new belt, the drive was loading and readinig the discs pretty nice.
On the inside, it's pretty straight forward:
There is a toroidal transformer for power and the CD-ROM drive is connected to the main board via de IDE ribbon cable. On the main board we see the power supply stage, the DAC IC (CS4392). This is a 24-bit and 192kHz DAC IC that boasts 100dB of THD+N in the datasheet. We can also see the tube buffer made with an ECC82 tube from JJ. Not sure if this is the original one or if it was replaced.
As you cabn see, there was a lot of dust inside and I tried cleaning it as much as possible.
Below you can see the detailed specs of the unit:
General
  • Manufacturer: Unison Research
  • Model: Unico CDP
  • Years of manufacture:
  • Made in: Italy
  • Color: black, silver
  • Remote control: yes
  • Dimensions: 435 x 95 x 340 mm (WxHxD)
  • Weight: 10 kg
  • Original price approx.: 1300,- - 1400,- €
Technical Data
  • Output tube: 1 X ECC 83 (Class A triode tube output stage)
  • D/A converter: 1 x Crystal CS 4392, stereo converter
  • oversampling rate: Crystal CS 8420 24 bit / 96 Khz
  • Output impedance: < 100 Ohm
  • Display: Toshiba LCD graphic text display. 128x64 pixel resolution
  • Remote control: System remote control made of plastic, wooden remote control optional
  • Drive: Highly selected Teac CD Rom drive
I was not able to find and THD or THD+N figures so I didn't know what exactly to expect. As it has a tube putput, I was expecting pretty poor THD+N performance. Let's see if I'm wrong or not.
For the measurements I used @NTTY 's test CD, version 7.2 (again, many thanks) and my Cosmos ADC (gdare A) + Cosmos Scaler.
Here is the 1kHz test tone:
WOW! This is really bad :). The second harmonic is through the roof at around -60dB and this dictates the overall performance of THD+N at -57.5dB. We can also see the evidence of high noise as the graph is tiled towards the high frequencies. The two channels were pretty well matched and the output level at 0DBFS was 1.7V. That being said, the third and fourth harmonics are pretty low. There is a debate on the audability of the 2nd harmonic and I can clearly say that I can't hear it at -60dB. I used my headphones and REW and added distorsion over the 1kHz test tone and I was not able to hear when the 2nd harmonic was added. I could clearly hear the 3rd and 4th but not the 2nd. This is just on the test tone. In real life, with a complex signal as music is, there's a high chance that you will hear it. Nevertheless, this is rather poor performance as I was expecting when seeing the tube buffer.
Let's see at -6dB:
We can clearly see the tube at work. With a lower amplitude signal. the 2nd harminic is lower, giving us a slightly better THD+N of -63dB. This is still abismal in my oipinion.
Frequency response looks pretty flat:
Here is the oversampling filter response:
The filter starts attenuating at around 21kHz and at 23.5kHz it hits it's maximum attenuation of around -75dB. Not great if you ask me. We can see rather large ultrasonic artefacts between 30 and 40kHz at around -60dB. We can clearly see the noise shaping happening after 30kHz.
Let's see the multitone:
As expected, this is not great. We have around 75dB of useful range, that is 12.5 bits.
Jitter:
This looks good.
THD vs frequency at -12dB:
Being at a lover level, this is not as bad as the full scale signal, but still pretty bad for a CD player. It's 20dB shy of what it should do.
Now the "intersample-overs" table with the units I measured so far:
CD player
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Marantz CD52mk2 - SE-34dB-27.6dB-16.2dB
Marantz CD67mk2-37.6dB-29.1dB-19.3dB
Marantz SA-14-47dB-32.6dB-21.4dB
Unison Reserach UNICO CDP (single valve)-34.6dB-27dB-29.6dB (only at -1.01dB) - H3 dominated
I did not perform the measurement for 11025Hz and +3dB as I could see clipping already at -1dB. The graph looks pretty bad when moving from +0.01dB to +1dB (see below):
@+0.01dB
and @ +1.01dB
This tells me that already at +1.01dB it is clipping and it going higher will not give us a diferent result.
Now let's see some IMD graphs:
The performance is poor at around -60dB. I like seeing the IMD graphs but maybe I'll switch to a list like @NTTY is doing in his reviews.
I did not perform any tests on the speed of the drive but I can tell you it's slow. For starters, it take 30s for the unit to warm up as it waits for the tube to get up to temperature. In this time, there's a countdown on the screen and you can't do anything but wait as the buttons do not respond. When going from one track to another it's ok, but when you want to skip several track, it takes a long time as you can't skip several tracks at once by clicking on the buttons, you have to wait for the next track to start and only after this, you can skip to the next one. This might be due to the fact that it uses a computer drive instead of a dedicated drive for audio.
Conclusion:
Well the measurements speak for themselvs. This is not a well pwerfoming device and I can't see any reasons why you would buy one, considering the price of around 1000EUR. There are many new options that perform far better. It doesn't sound bad as I can't really hear the 2nd harmonic but we can't deny what the measurements show. For some reason I was not able to test the digital output of the unit. I suspect it's a far better option to use an external DAC in order to avoid using the internal one. The internal DAC itself is not bad, but the analog stage containing a valve is not doing a good enough job.
I hope this review helps you if you were lookinmg at the uinit second-hand.
All the best,
Horia
oversampling rate: Crystal CS 8240 24 bit / 96 Khz
Make that a CS8420.
This player is kind of the worst of all worlds. The distortion of a tube stage and the intersample-over handling of an ASRC combined with a crummy computer UI, what's not to dislike? Doesn't look like there's overly much ultrasonic filtering for all the shaping noise the CS4392 is dishing out either. (This is pretty much the same DAC as found in the CS4272.)
Thanks for this - confirms my bias against ever buying "exotic experiments". :facepalm:
Botching a CD player this badly is almost an art...
Sadly not surprised after seeing other Italian CD players...
Also sad to see absolute C tier trash electrolytics in such an expensive device.
I really doubt this cap measures up to spec still:
Make that a CS8420.
I corrected it. It was just a copy/paste from another site. I did not check the data.
Yes, I've noticed the ELCOs myslef and I was wondering the same thing. I'll ask the owner if he wants to replace those. But even with new and good capacitors, the performance will still be abysmal.
This Unico has high 2nd harmonic distortion with (relatively) low higher order harmoincs -- there are people who will love it, (but not me).
I do not like the 2nd harmonic either but there is the argument that you can't really hear it. As I was saying in the review, I can't hear it when I test using REW and my headphones. Everybody can do the test as you only need REW and a pair of headphones (it could work on speakers as well). When I added the 2nd harmonic over a 1kHz tone, I could not hear it, although it was rather high in amplitude, at -40dB (1%). I had no such issue with the 3rd, 4th, 5th, etc harmonic. But the reality is that this test is only performed on a single 1kHz test tone. It is a different situation when you have several frequencies playing at the same time. So yeah, even if you can't hear the 2nd harmonic on a test tone, it will most probably be audible when listening to music.
They still exist and are still ploughing the same furrow:
How does this work with only one tube? I admit I don't know much about amplifier design, but wouldn't you atleast need one for each channel?
My assertion, above, that some people are going to like the Unico on account of its high 2nd order harmonics is based on my personal observations over several decades -- admittedly not science per se.
I'm talking here about how numerous audiophiles preferences for tube amplifiers correlates with measurements for the type of equipment that served their preferences. That is, tube amplifiers have high 2nd and/or 3rd harmonics relative to higher order harmonics.
The audiophile trek back from s/s to tubes was a phenomenon picked up momentum in the '80s. My interpretation, again based on personal observation, is that the s/s amps of the '60s & '70 had very low THD but that residual distortion was comprised of relatively more 4th & higher order distortion than 2nd/3rd.
2nd order preferers don't listen and say, "Aha!! I'm hearing 2nd harmonics"; they say that the music is sounding smoother, warmer, etc.
Knowing some of their amps of a long time back admittedly, this CD player is I suspect, rather better in performance than their amps. The market this thing sold into, wouldn't give a toss about distortion levels I can assure you and I'd posit that this awful (for digital) performance was designed in!
Could the CD-R drive be substituted for a more modern one I wonder?
The CD transport itself is little more than a DIY project.
You can get a controller for a computer CD drive, complete with remote control and display, for around €30. Data transfer simply uses the SPDIF interface on the computer drive.
Very basic.
Incidentally, the Teac CD-552E could also be used directly as a CD player and transport via the control buttons and volume control on the front panel. On the back, it had analog stereo outputs and a digital SPDIF output.
Nice review, thanks for the efforts!
I was about to ask if you checked the channel imbalance or output voltage / phase, etc... but considering the other results, not sure I want to know :)
About the digital output, and depending on the digital interface you use with REW, I'd suspect this player does not output 44.1kHz, but maybe 48kHz. You can try to connect it to another DAC and see what it reads as the input sampling rate.
As per your measurement of intersample overs, and as @AnalogSteph mentioned, the overflow you measured is typical of an ASRC, and I seem to recognize a CS8420 here, which would explain the results.
Thanks again for sharing!
This is for those that want tube distortion, it increases with level, lots of 2nd harmonic, much less higher ones. Why bother with a tube stage if its as clean as semis?
This device was designed properly IMHO.
As badly as this measures, I'd like to see a blind A/B to see if listeners can actually hear the defects. Seems to me that people can't actually hear nearly as acutely as they think they can.
...not because I want to say that this CD player is OK in some way, but just to use as an example of a measurably flawed audio source for testing if these flaws can actually be discerned by listeners.
My guess is that a few rare listeners would be able to hear this level of misbehavior, but at the same time I'd bet dollars to donuts that MANY "audiophiles" would not be able to tell the difference in this vs. a pristine player.
I conducted a small test with an Audio-GD DAC that I had which measured very poorly* vs a Topping DAC which measured great. Neither I nor any of the several people that listened to this A/B - including a pro musician - could reliably hear a difference.
*I sent the DAC to Amir for testing, the results appear here => https://www.audiosciencereview.com/...d-measurements-of-audio-gd-nfb2-192-dac.7807/
...Seems to me that people can't actually hear nearly as acutely as they think they can...
This, and, even if they hear it, they can still perceive it as better, if it's either louder or "interestingly distorted".
IMHO many if not most listeners overestimate their capabilities.
