Uninterruptible Power Supply for AVprocessor
I’d recommend against lead acid full stop, it’s very sensitive to temperature in terms of longevity and unless it’s in a temperature controlled environment is likely to simply be a false sense of security.
It sounds like the OP really wants a PDU (power delivery unit) that allows the outlets to default to off after a power interruption rather than on.
All of mine are inside the house, so reasonably temperature controlled, at least enough that was not a concern. But temperature sensitivity is not better for all LFP batteries; in fact, LiFePO4 batteries are worse than lead acid at temperature extremes, at least from multiple sources when I was researching them a few months ago. Longevity and capacity/output are both impacted by temperature, and recharge cycles much more limited (like 10:1) for lead-acid compared to LFP. But for a household UPS meant to survive a brief outage it was not worth it to me to go LFP. Hopefully the price will come down soon.
Most domestic situations are going to reasonably temperature stable - my last UPS battery was fine after 6 years when I sold it (to go travelling).
If you just want to have mains sockets that will default to staying off after a mains outage, use any wireless-controlled (not 'smart') plugs. I use several of these around the house so I can use a remote control to operate them. For example, the LED lighting in the attic. When the mains go off, these plugs (with built in sockets) stay latched off until you press the right button on the remote. It may even be a requirement that they behave like that. I think mine, bought on Amazon, were branded Dewenwills or similar. I have two sets of three plugs each (two remotes) for various uses. They've been working well for over 5 years.
I've used Cyberpower for years now. Just the modified square wave ones for computer stuff but splurged on a CyberPower CP1500PFCLCD PFC Sinewave UPS for the home theater. It triggers probably about once per month that I notice just based on seeing the display light up. A couple of times since I bought it back in May 2024 the power has stayed off for more than a few minutes and I end up running an extension cord from the closest outlet powered by the more serious 2.5kW inverter (with about 5kWh of LFP storage) just to make sure it doesn't run out.
The power plugs of my smart home (Bosch) do this. Software feature, user configurable. I don't think it's unique, other good plugs should have that too.
If the problem is short outages in a row / on off flickering power - a destroyer of devices - either a UPS or such a "stay off after power loss" helps.
My main concern is that the power sometimes comes back for just a few seconds multiple times before it’s solid again & I’m trying to give my MP-40 an easy life, it was a huge investment for me & getting Lyngdorf gear serviced is very expensive as it has to be shipped back to Denmark.
If you're concerned about multiple power cycles after a power cut, you might considier using an AC starter. It might be called different things in different countries.
It's an AC contactor or relay with start and stop buttons that keeps the power switched on when the supply is on, but switches the power off permanently whenever there's any interruption (until you turn it on again). It's mainly used for industrial plant where you can't have something switching on by itself. They're not expensive, and they've solved a couple of complicated problems for me.
That’s a great suggestion Nick, thank you, I want to go all in though & also protect against power outs during boot up, I’ve settled on the Cyberpower CP900EPFCLCD-UK but it’s currently out of stock everywhere, looks like they are updating the range as the two models above it are showing updated versions available soon.
Pretty much all of the radio controlled sockets (with an RF blipper button unit) will handle 13A loads (claimed), in the UK at least and latch "off" immediately on power loss. More than enough for a HiFi, and the triple set in my link above is only £22. I'm not sure we need gear for big electrical installations!
If you are going for an upper level UPS, look at availability and costs of the next set of batteries. Aftermarket choices like for APC?
Also look at reviews. Quite some UPS go out of service because of their electronics somewhere between 6 and 12 years of service (my work experience).
Cyberpower/Bluewalker models showed some rather harsh behaviour when unloaded below 30%. Not this model, various others. I'd recommend you chose a capacity more in the 1000W range and begin shutdowns at 50%. Or do test the behaviour prior to usage.
You probably don't need a sinewave model, but they are nice to have. Better quality, software, options. But if your requirements are simple (no PC scripts, SSH, SNMP, etc.) you could opt for something cheaper.
If I had the mentioned processor and power problems, I would use a good UPS too. The model for workstations that worked out best over a longer period at work was the APC BR1600.
I don't put amplifiers (including AVR's and active speakers and subs) on UPS's. But gladly put most everything else on one. Cheap ones can increase your AC source impedance and make it harder for the amps to get instantaneous power delivery.
A good breaker-panel-located surge protector is all I really want for amps, and a dedicated circuit. I've pondered using a true A/B changeover switch to connect amps to mains and switch-to the UPS-fed input during outages - but never bothered hooking it up.
Some newer Subs like SVS Revolution series actually incorporate full power conditioning/filtering/surge right into the PSU as the SB5000 for instance has a full 15Amp AC-Mains rating and makes it hard to condition properly with "Cheap" conditioners and nearly impossible to power off a UPS anyway. A good unit's PSU should handle anything a cheap power conditioner/UPS can also handle - so I don't feel much extra "Protection" is provided...
But every Desktop PC and NAS, all DirecTV+ RF Distribution, TV's, all Internet/WiFi infrastructure, and fish tank pumps run off UPS's (one big centrally located one for most stuff, and small 1000VA sized units scattered about).
Subwoofer on UPS. :D
Luckily the Lyngdorf is below 100w. Just very expensive.
Received my Cyberpower CP900EPFCLCD-UK yesterday so will be connecting it up this weekend.
A big thank you all
