Uninterruptible Power Supply for AVprocessor
Ssss
Hi all,
Could anyone please recommend a suitable Uninterruptible power supply for my Lyngdorf MP-40?
We get a few power cuts in our area (UK 230V) & I’d like to be able to power down my MP-40 properly If the power goes off while the system is in use.
I’ve read that I should be looking for a unit with “pure sine wave with automatic voltage regulation” but have no experience with these things & could use some guidance.
Many thanks
Jason
You don't need one.
The main problem of unexpected power loss is when there's a chance of uncommitted disk drive writes - this is not applicable, as the only thing Lyngdorf stores seems to be a backup of its system settings AFAICT.
It should recover fine after power loss, unless the internal software is poor (my streamer-amp doesn't care - ask me how I know!). It's easy to test by flicking off the switch on the mains socket if you want.
Same applies for your networking gear, as the Lyngdorf uses similar, fairly basic CPU modules as used in routers (sure, more powerful, but not like a PC).
As for pure-sine or not, most decent SM PSU won't care. I had a basic inverters on my 5th wheel caravan, and audio/TV/guitar gear all worked noiselessly.
If you still worry about power loss when listening, just buy any cheap UPS from Amazon, and when the power goes, you should have time to manually power the device off, but bear in mind most still use lead batteries that need changing every few years. Try it for noise - if you hear any from it, send it back for a refund.
You don't need one.
Thanks so much for taking the time to give such a detailed response, greatly appreciated.
My main concern is that the power sometimes comes back for just a few seconds multiple times before it’s solid again & I’m trying to give my MP-40 an easy life, it was a huge investment for me & getting Lyngdorf gear serviced is very expensive as it has to be shipped back to Denmark.
When our power went off earlier this week, I turned off all the sockets that had electronics like TV or audio attached (I generally turn off stuff I don't need until power is solidly restored).
I have found in the past (albeit when I lived in USA), when the power is restored, you can get surges, and occasionally some kit will suffer. It's not beyond belief that a surge may damage a cheap domestic UPS too!
Probably not 100% protected but I fitted a dedicated consumer unit with integrated surge protection device for my AV kit.
I’m not paranoid…..Much!
I'm not sure, but anti-surge may be a requirement in fuse boxes now - there is one in ours, a new box fitted 4 years ago. They degrade and change colour over time when surges pass through..
I think however, these are more to stop the fuse box or house going up in flames in the event of lightning strikes :)
I doubt they stop much of the noise spikes and possible over-voltage that you get when external HV gets switched. A cheap in-line mains filter may help with that.
The last device we lost in Cornwall a few years ago was a water-pick in the bathroom (there had been a brief outage but the root cause could not be proven). I suspect such things have super-low spec/cheap internal power supplies.
I have power supplies destroyed by multiple rapid off/on power glitches.
Several computers and a computerized sewing machine.
In addition, I have had to unplug devices and wait for various lengths of time to reset them.
Your power company may not do this, but where I have lived, tree branches in high wind can cause multiple brief outages.
I keep all of my computers, routers, and devices that are computer like (Trinnov Nova) on UPS both for convenience and for the short power drops we have from time to time. It makes life a bit easier. I doubt there are any that are better than others for audio equipment.
We have experienced some weird glitches unrelated to lightening.
One glitch destroyed a cheap Fosi amp and its power supply, required removing the batteries from my home thermostat to reset it, and required unplugging multiple devices to reset them.
Most of these devices were on surge protectors.
I now keep the TV and associated audio equipment on UPS.
In a past life, I had to specify UPS systems for data centers, when data centers were small. The classic UPS is double conversion, it takes the AC from the grid mains, converts it to DC, charges the batteries, then takes the DC from the batteries and converts it back to AC using an inverter. The AC, even from a pure sine wave inverter, will have switching noise. So the 50/60Hz will have harmonics. Many UPS systems use sealed lead acid/AGM batteries with limited life or other rechargable battery chemistries.
The power supply in audio equipment filters out the harmonics.
Today there are many Chinese manufacturers of solar power packs and home backup power systems. They work on the same principle as the above mentioned UPS. If the mains power is lost, they may need to manage the mains ground. In the last year, to add features, they have made switching to UPS mode under 20ms. 60Hz is 16.67 ms.
You can check the specs on each product. Typical brands in the US are Ecoflow, Jackery, Bluetti, Anker, and a large number of smaller makers. The rest of the specs will be the years of warranty, the output Watts, the Watt-hours of the battery, and whether expansion batteries can be attached to increase the Watt-hours. Usually they will have Bluetooth and an app to look at basic parameters and update firmware. They will have a fan if they are more than a few hundred Watts.
Anker is a well known Taiwanese brand of good quality. I like Bluetti, first long warranty, first to use LiPO4 batteries and they have introduced a sodium ion unit. Their pricing is highly variable, so buy on their sales. Their drawback is short product cycles and too wide a product line, they discontinued a favorite line for which I wanted to buy one more expansion battery.
The Bluetti Handsfree 1 is a nice small UPS.
Larger ones can run critical home loads like a refrigerator. Or can run your home Internet through long outages. Add some portable solar panels to their solar input and you can run indefinitely.
Surge protectors? Are these the power strips the claim surge protection? I'm not sure how many of those work as advertized.
For noisy transients - even a fridge on the same mains ring - the filters do help slightly; I have tried this in my previous house and it worked to quell pops and clicks when the fridge compressor motor started up.
I would say that even in "Broken Britain", the mains feeds for most households is pretty clean, surge-wise, and most people here would probably not get their money back on buying a UPS*. Maybe it's helped by most power feeds to houses being buried in the street (unless you live somewhere very rural), all the way from the local substation. In the US, I don't recall living in any house that did not have street poles for power to the house, even if the last few metres of feed was underground, but maybe that was random!
*for many years I had a mid-size APC unit that I got free from a tech company doing some downsizing - all it needed was a new battery. The problem was that it connected to one mains socket, and while it could feed lots of downstream devices (up to 3kW for a period of time), I could not have loads of trailing cables around the house, and so I had choose where I thought I could deploy in to best effect. Clearly, it was my basement office with several PCs and RAID storage, rather then where my main audio gear was in the lounge. If I had put it there, that would have had serious WAF consequences.
My stereo, TV, internet modem and router are on a UPS back-up. Might as well have a simple device that smooths over one of life's little glitches, like an infrequent random momentary power outage.
I have used many APC and some other units over the years, and recently have bought mainly CyberPower UPS systems as they offer "sinewave" power that is cleaner than the cheaper APC units. APC BackUPS have a stepped sine approximation that is a very rough approximation; SmartUPS have sinusoidal output but are expensive; I do not remember what CyberPower calls their sinewave units, but they are comparable in price to BackUPS with better (more sinusoidal) output. Plus APC got ridiculous on replacement battery prices, and the last few units only lasted a year or so, so out of warranty coverage. No idea what they have for 230 V UK lines, however.
I have almost everything electronic on some sort of UPS, mainly to ride out short glitches and allow me time for clean shutdown in the event of longer outages when I don't want everything on the generator. It's been better lately, but we still have power glitches that rapidly cycle on and off, and outages that last for seconds to days. Short glitches are actually the worst as not all power-on circuits adequately recover and reset for a very short glitch, leading to damaged components, and expensive repairs or replacement.
Thank you very much, I’ll check out Cyberpower
I recommend against any cheap, lead-acid based UPS as they are generally just going to be another item to fail during an outage. Probably your best bet if you really want a UPS is one of Goldenmate's LFP-based UPSes. Or use one of the many LFP "battery generators" on the market from the likes of Anker, Jackery, Bluetti, Ecoflow, etc. Justook for the models that are rated for 20ms or lower switching times.
Surge protection is best handled at the load center. If you don't already have a whole-home surge suppressor in the load center, inquire with an electrician about getting one installed.
If you are just depending on the UPS to get your equipment thru power outages, it shouldn't mater whether its "true sine-wave" or not.
True for most things and short-duration events. Some of my stuff really hated the low-grade stepped approximation of the cheaper (older) APC units and would overheat, though that may have been cheaper transformer wall warts (most all use SMPS these days). No idea if APC has improved their filtering to prevent that, but I have not had any problems with CyberPower, or APC SmartUPS. Motors in particular, like the air and water filter pumps for my aquarium, needed a SmartUPS to prevent overheating within minutes to an hour. Since getting a whole-house generator years ago, the problem has gone away for long-term outages. Before then, only a couple of things cared if the AC power was pretty "dirty". The generator's output is not as clean as the direct line but is much better than some cheap UPS outputs. For reference, the generator's distortion is specified at 5% max, while our line is around 2% (I believe code says 5% max), my CyberPower CP1500 is below 2%, and the stepped-sine APC BackUPS exhibited about 10% distortion using a DSO. The APC was an older BackUPS unit; I do not know how current BackUPS or BackUPS Pro models compare. The SmartUPS was around 1% IIRC, but about three times the cost of the equivalent BackUPS at the time. Numbers all for off-line UPS units running off the battery, and the generator running under our normal house load (didn't turn anything off but I do not know the actual load, need to see if I can measure that at some point, or find in the generator's menu).
LFP battery units are great but pricey, roughly 2x the price for equivalent VA ratings here (USA) when I looked a couple of months ago, and some of the units (including Goldenmate) have much lower long-term (e.g. one-hour) run times. I thought about an LFP unit but decided I did not need it for my applications, and one thing that caught my eye was that a 1500 VA unit was only rated around 300 VA for an hour. I did not look further to see if the reduced long-term capacity was limited by the battery itself or something else like thermal issue with the inverter. The reduced long-term capacity was not an issue for me but might be for some.
Other units may have similar long-term operating issues; an APC server unit at work rated at 2500 VA with extra battery packs got pretty hot running for about 30-60 minutes at around 1500 VA, even with internal fans to keep it cool. Usually our back-up generators cut in long before that, but once when they did not, that thing got hot!
I have had many battery failures over the years, but they are usually easy to replace, and fairly cheap. Some years back APC had an inverter problem that just killed them for me. I replaced several batteries on units around one year old only to discover the inverter was bad. The UPS were out of warranty, but APC offered to refund the replacement battery cost once I shipped it back to them (on my dime) and they verified it was OK, but only if I bought the battery directly from them. That's when I found out that Amazon does not always use authorized resellers, though APC was able to confirm my replacements were from an authorized dealer and offered to refund or credit toward a different UPS or replacement battery. I passed as I could use the batteries in other units around the house.
I’d recommend against lead acid full stop, it’s very sensitive to temperature in terms of longevity and unless it’s in a temperature controlled environment is likely to simply be a false sense of security.
It sounds like the OP really wants a PDU (power delivery unit) that allows the outlets to default to off after a power interruption rather than on.
