Hi. I am trying to buy a new TV (small 43") and I need some help in understanding the connectivity options. I am mainly interested in good quality 2-channel audio for music, and am hoping to reuse my current hifi amp/speakers to improve my TV sound. The TV sound is very much a secondary consideration.
Currently, I have a Sony BRAVIA (2013) which has a variable analogue audio output via a 3.5mm headphone jack. I simply connect this to my amplifier and use it with my speakers. The nice thing about these old BRAVIAs is that the TV speaker can remain on, so I end up with the TV producing most of the sound with the hifi speakers adding much needed support to the lower frequencies. The secondary benefit of this setup is that the volume is controlled through the TV remote (due to the variable analogue headphone out on the TV). This has worked well for the last 12 years.
Based on my research, new TVs very rarely come with analog audio output. I am learning about HDMI ARC and how that can help.
The problem is that I am hoping to use the TV speakers like I have in my current setup, but I am struggling to understand which TVs can support providing output to both the TV speakers and HDMI ARC at the same time. I understand that some Sony TVs support dual output, and there may be equivalent settings for LG and Samsung TVs, but it seems to be a minefield in terms of compatibility. I am also worried that I will end up with delay between the different outputs (especially if I use something like a Wiim streamer to provide the HDMI ARC connectivity and parametric eq).
Alternatively, I could give up on using my existing 2-channel hifi with the TV and add a soundbar and sub woofer to the new TV, but that seems to be a poor compromise.
Is there an easy way I could add a center channel to my setup if I can't use my TV speakers? I am not sure how this could be done ...
Or is there a simpler way of connecting TVs that I have not yet found? Any ideas would be really appreciated.
Thanks, John
Thanks, John
