“I would not use the value given there since the woofer's bandwidth is limited (i.e. there is no tweeter). It only works if you are measuring speakers with HF drivers with the range the chirp uses.” Quoting myself.
I can believe that. I noticed that the tweeter chirp is almost useless for measuring subwoofer timing. I took perhaps a dozen sweeps of my subs and examined them all for consistency, and they were hopelessly off with no consistency whatsoever. So I switched to loopback and did a few measurements. I did half a dozen, and all of them were reasonably close. Take a look:
Mind you, I don't believe those subwoofer timings one bit. First, it is -3.75
seconds which would appear to violate the principle of causality. And the total discrepancy between the subwoofer and the mains is 5.8
seconds. I was aghast when I saw this so I rechecked the measurement setup and cross-referenced it with Acourate's loopback timing measurement. The good thing about Acourate is that it allows you to zoom in to the impulse peak and verify the reading yourself. The bad thing is that the excitation signal is a Dirac pulse (a click, not a sweep), meaning it is very low energy.
As you can see, the measurement is heavily contaminated with noise. Regardless, Acourate's loopback measurement gave me roughly the correct value of about 6.5ms (you need to subtract the tweeter loopback measurement which I did not show).
So REW's loopback measurement is consistent, but it is also consistently wrong.
And it's not the left side either. REW thinks my R sub is 5.9 seconds delayed to the R speaker using loopback.
Using the delayed tweeter method that I described earlier, I know that my subs are delayed by about 6.5ms. That seems about right.
This comes across as rather absolute and final but it's possible, likely even, to be user error or related to your particular environment/speakers. As a counterpoint, I have been given measurements by someone using it to design a passive crossover for them (more than once in fact, with off axis measurements as well). I designed it, they built it, measured it, it worked as expected. You can't do this if it's unreliable in general. I have also used it in the past with no obvious issues (albeit I do have hardware loopback so don't generally use it)
Maybe you're right, maybe it's just me. Or maybe not many people repeat measurements, checks them for consistency, and cross-checks them with other methods of timing measurements like I do. So their timing measurements could be completely out of whack and they don't notice it.
I have spent enough time experimenting with REW's acoustic and loopback timing measurements to be really sceptical of it. When I saw those weird readings, my first thought is that I did something wrong. So I used the same setup to take loopback measurements with Acourate just to verify the measurement setup, and I got realistic readings. I heard that some USB ports are less reliable than others, so I tried another USB port. No difference. So i'm out of ideas.
