.wav to .bin converter:I agree with OCA's opinion.
I've seen some users export WAV files, then import them as raw files into Audacity and change the file extension to .bin to use them.
I haven't been able to test it myself since I no longer have a MiniDSP.
So, I'm not really sure if that actually works.
By the way, A few simple examples.
(I still don’t fully understand the API (always grateful to @JohnPM for REW), but users like @OCA automate it and use it effectively for their purposes. - So, if you have a good knowledge of API, you can either automate it or do it manually.)
Limitations of MiniDSP
... or any other DSP with only 1024 taps per channel. Over the weekend, I went to a friend's place to help generate some filters for his system. His system consists of 2 subwoofers and 2 mains, with a MiniDSP SHD, which accepts a 2 channel input, convolves filters, and has 4 analog outputs. It...
audiosciencereview.com
