@Keith_W
Learning a lot about DSP in this thread. Thank you!
I don't deserve all the credit (apart from starting the thread), I think the ASR community also deserves thanks. Plenty of knowledgeable folk here.
How would you evaluate the DSP capabilities of Hypex Fusion amps?
According to
the manual:
15 biquads per channel for a plate amp intended for subwoofers is plenty. You will use maybe 1-2 biquads for the low-pass, which will still leave you plenty of biquads. I did not do enough reading to find out how you program the biquads. Remember the warning I gave in my first post: biquads have poor portability. If you want to use REW (for example), then REW needs to be able to specifically export biquads for Hypex Fusion.
HOWEVER, (IMO!!!) it is not a good idea to implement DSP on subwoofers only. This is because:
1. Subs are usually delayed with respect to the mains. The correction involves delaying the mains to match the subs. However, DSP on the subs adds additional subwoofer latency, which worsens the alignment between mains and subs.
2. you want to use DSP to tie subs to the mains, which means that both the mains and subs should be DSP'ed together. Of course you can have one DSP unit for the sub, and another DSP unit for the mains, and then somehow program these two independent units to work together. But this isn't going to be easy, and it will drive you nuts trying to figure it out. Some people enjoy the challenge, but I am not that much of a masochist. It is better to have a single DSP upstream of both speakers that can control them together.
My personal opinion: I would rather have a "dumb" subwoofer. The only features that subwoofers need to have is a signal detecting auto on/off switch and a volume control. And of course, size, styling, max output, distortion, etc. + all the usual considerations. I don't need anything else, I will control it all from DSP.
Pros love this kind of solution though. There are many amps on the pro market that are DSP enabled. They distribute the DSP load over multiple amps and speakers, then use another layer of DSP to control it all. For example, Powersoft makes an 8 channel amp, and each channel has its own DSP with biquads. You could use this amp to correct a single speaker. You then deploy maybe a dozen of these things, each speaker corrected to be "perfect". Then you tie it in with another DSP layer that makes them play together.
