Devnull
First off, stereo subs located in the front corners will give you tremendous stereo separation from 200Hz to 20Hz. It would also work for mono with a lower XO point.
Having your subs a little wider than your mains will not be audible. We can hear stereo in low bass, but our sensitivity to stereo is less acute than in the mids and highs.
There are a few things, though, to consider:
• The mains will need to be delayed so that they are properly time aligned
• Corner placement will require some low EQ shelving due to the corner boundary acting like a horn (room gain… it’s like getting a couple hundred extra Watts in amp power)
• It could excite room modes that will need to be tamed
• I’d never buy a sub that can’t reach past 200Hz. I prefer two 12’s to a single 18 inch even though they move the same amount of air.
Explain to us how you do your speaker management.
AVR or separate DSP? What happens to the LFE channel if you want to use it for something other than music?
Is 20-200 routed to all subs? Is it mixed into one mono signal? Is R only routed to the subs on the right side of the room?
How do you do time alignment between the subs and speakers? Time alignment between all the subs?
How is this implemented if you don't have a uniform rectangular room?
