Not to bust your chops, but go to Parts-Express.com and check out the comparably sized subwoofer drivers. All of the ones I’ve considered for designs (10”, 12”, 15”) are “flat” to about 800Hz or more.
I’ve seen that some of them, when tested, exhibit higher distortion above 150Hz.
Personally, I’d never consider a sub with less than flat 20-200Hz response. I’m running KEF LS50s and they have to be XO’d at 170Hz minimum.
First, my mains semi-anechoic (with no EQ of any type) FR is +-2DB 26Hz-20KHz.
Why in the world would I want to go up to 200Hz? That is well into woofer territory (which is definitely not needed from a sub in my system).
Parts-Express has nothing like this:
Perhaps you haven't tried a real sub: a 24" sub in a large transmission line, 60x28x24? (in my case, a pair). Yes, I know, not living room friendly and yes, my wife does not like them. And they will eventually be replaced by something more aesthetic.
Some construction notes of the subs I'm talking about (now out of business [1927-2015]).
(They may soon be back, though (according to them):
Renowned for coining the term “High Fidelity,” Hartley—an iconic innovator in loudspeaker design—has returned to production under the stewardship of Tri-Art Audio. In collaboration with former owner Richard Schmetterer, we are committed to preserving and advancing the Hartley legacy. All milling, fabrication, and finishing are undertaken in-house at our manufacturing facility in Kingston, Ontario, Canada.
Hartley Loudspeakers are currently in pre-production as we refine the final details for launch. Comprehensive product information—including specifications, pricing, and shipping options—will be released gradually as we move toward our formal debut in Spring 2026.
We sincerely appreciate your interest and look forward to reaching this exciting milestone, and to sharing the full scope of our next-generation designs in the months ahead.)
THE HARTLEY POLYMER LOUDSPEAKERS
In the past, very spl people have known about HARTLEY speakers. Audiophiles, engineers, musicians, recording technicians, scientists and other professionals who use sound or consider sound to be a very important part of their lives or careers. No matter what the price, HARTLEY speakers are considered among the best available anywhere in the world. Meticulous hand-crafting and unique problem solving of the physics of loudspeakers are the reasons for our long standing reputation. We don't sell a lot of speakers that way, but we don't have to compromise our standards either. In fact some of our drivers require over fifty hand operations to build.
THE CONE
Only in recent times do we find companies using cone materials other than paper: polypropylene, Kevlar, aluminum, synthetic polymers and other plastic formulations to name a few. Their more recent revelations was our understanding over FIFTY years ago! Starting with polymerization to paper cones, in 1956 Dr. Harold Luth, chief engineer and Master Chemist developed the World's First Synthetic Loudspeaker Cone. Until that time the only non-paper cones were that of Bakelite paging speakers used by the Navy. To accomplish this truly revolutionary feat Dr. Luth had to invent a new synthetic to which the world had never seen. A series of monomers cross-linked became the solution which led to other problems and solutions. Plato's' loudspeaker cone is one that has: no mass, infinite stiffness, perfect geometry and ultra-fast sound transmission time. Dr. Luth choose a molding process with a special fabric carrier and internally molded ribs. With his physicist hat on (and pipe) he designed a superior geometry never before seen. The cones were shallow, incredibly light and stiff and could withstand high molecular pressure without edge nodding and bending.
THE SURROUND
Most speaker driver manufacturers use foam, treated cloth or butyl rubber as their compliant surround. Foam, untreated will deteriorate inside-out from humidity and moisture in the air. Treated cloth is much less compliant, and exhibits more resonances. Butyl rubber a much better choice will break-down due to ozone in the air. The solution Dr. Luth determined due to his extensive background in chemistry was silicone rubber. Totally inert, extremely low resonance, proper durometer, impervious to moisture, as well as UV rays and a lifetime of greater than 99 yrs. Every other manufacturers surrounds are glued to the cone. This can lead to spurious resonances and even separation at the joint. Dr. Luth's solution was to change the chemical mix during molding from polymer to silicone rubber thus eliminating a joint completely. A seamless molding solution!
THE VOICE COIL (MSG Models)
The dual voice coil in the HARTLEY speakers (220 MSG & 207 MSG) is based on a principle first developed by the British physicist, A.C. Barker, in 1938. Barker's "duode" coil consisted of two coaxial windings, isolated by a plastic film. By transformer action, high frequency signals imparted to the copper windings were induced on the aluminum shorted turn. The aluminum tube could move independently of the copper windings to vibrate the speaker cone to which it was connected. Barker's voice coil, although sound in principle, was never fully successful because he was never able to fully isolate the two sets of windings with the materials available at that time. However, developments in synthetic chemistry have enabled us to produce a highly compliant silicone compound, only 4 mils thin, which isolates the windings effectively and permits the inner aluminum tube to move independently at high frequencies. The HARTLEY aluminum tube is a complete circuit not slotted. It should be noted that in the HARTLEY speaker, the aluminum and copper windings are each connected to respective sections of a dual cone. In the Barker voice coil, the aluminum tube was the only part of the assembly fastened to the cone. Electrically, the dual voice coil may be considered an air-cored transformer, modified somewhat by the presence of a small amount of iron on the pole piece of the speaker magnet structure. The copper windings and aluminum tube comprise a voltage step-down transformer, in which the copper turns are the primary and the aluminum tube the secondary. Signals fed to the copper windings of the voice coil are induced by transformer action on the aluminum shorted turn. Because it is a step-down transformer, the induced voltages are lower and the current higher than the primary voltages and currents. Air-cored transformers are quite inefficient at low frequencies. Consequently, the current induced in the aluminum tube begins to drop sharply at 2000cps and virtually disappears at 1000cps. An elegant way of eliminating a crossover with its losses and distortions.
THE HEAT SINK (HS MODELS)
All HARTLEY HS woofers employ a unique "heat sink" which is actually the aluminum tube the voice coil is wound on. The tube is cut so that a significant portion protrudes through the apex of the cone allowing the greatest concentration of heat (around the coil windings) to be dissipated through the tube outside the cone and into the air. During the coil winding a special high temperature epoxy, manufactured by HARTLEY, is applied to all layers of the windings and baked in with a temperature of over 450 degrees F. This extreme temperature far exceeds the rating of the copper wire itself!
THE SPIDER
In the first HARTLEY speakers in the 1920's our spiders were made out of Bakelite and had four legs that were bolted to the magnet structure. The shape defined the name "spider". Today we still employ the same design but with materials to meet 21st Century standards. Spiders for the polymer series are made from tri-laminate fiberglass which is impervious to adverse weather conditions and strong enough to withstand parallel and perpendicular forces.
THE FRAME
Most driver manufacturers use stamped steel frames. These stampings are inexpensive but they exhibit unwanted resonances. Ringing is often used when referring to this steel frame. All HARTLEY polymers drivers use a sand-cast aluminum frame, light and strong, inert and then polished. Yes, an expensive way to make a speaker frame.....also the best!
(EJ3: in their opinion and mine [for the moment]).
