Most, if not all, port reflex designs exhibit resonance.
Since it's a compromise to achieve some bass, and given that we'll be using subwoofers, we can close the port, which is no longer serving its primary function but still muddying the midrange, especially at high SPLs.
2) By closing it, the enclosure becomes sealed, which reduces group delay and makes it easier to integrate the subwoofer. This is true regardless of the port's perfection.
The bass reflex design is a fantastic invention, but poorly suited if the speaker needs to reproduce the midrange frequencies.
To me, the title: Understanding Subwoofers indicates frequencies below midrange or woofers (and is the way that my system is set up):
My mains have a very small bass-resonance peak (without any EQ of any type):
The close-miked woofer (and port) response of the mains: At the system resonance of 60 Hz, the output is only about 2 dB above its average level in the upper part of the woofer’s range, and even that minor output variation was spread over almost two octaves. When the bass curve was spliced to the room-response measurement, the resulting composite frequency response was flat within about ±2 dB from 26 to 20,000 Hz. The horizontal directivity of the tweeter was only discernible in the room measurement above 10,000 Hz.
At 90-dB SPL at 1 meter, the distortion is less than 1 percent from 100 Hz down to almost 60 Hz, the effective crossover to the port. Below that crossover the distortion rose to 5 percent at 45 Hz and 9 percent at 35 Hz. In high-power tests with single-cycle tone bursts, the woofer began to sound “hard” at about 350 watts into its 8.5-ohm impedance at 100 Hz. At higher frequencies the amplifier clipped—at outputs of 490 watts at 1.000 Hz and 1,380 watts at 10,000 Hz—before distortion became visible on the acoustic waveform.
Quasi-anechoic FFT measurements shows an overall group-delay variation of about 0.1 millisecond between 4,000 and 20,000 Hz and 0.5 ms between 1,000 and 20.000 Hz, convincing evidence of the attention paid to the phase characteristics of the Dahlquist M-905.
Each main and each sub have their own amp that can (if needed) put out over 1600 watts RMS.
My pair of passive sub-bass speakers (the raw driver) have a rated FR of 20Hz-80Hz.
I have the HP at 55Hz & the LP at 70Hz (coming out of the Pre-Amp [before going to the amps]), so I am pretty sure that the subs are not trying to do any midrange.
