Eh? This would seem to contradict the notion of EQing out room mode peaks below Schroeder, unless I'm misunderstanding you.That region between 80Hz - 400Hz is typically non-minimum-phase in most rooms and thus can not be equalized.
It might just be confusion on my end, but this seems to show that cardioid bass does indeed have a benefit in reducing SBIR, which is the more common cause of issues in the ~100-200Hz area. This is reinforced by your showings of positioning the speaker close to the wall. This is unsurprising. I think a lot of people are thinking of room modes when they are talking about "room interaction", though, and given that all these measurements (except for the last one, which shows a big room mode peak) are equalized under 100Hz to address room modes these wouldn't seem to support the notion that the cardioid bass necessarily has a beneficial effect with regards to room modes in particular.I do, and they do indeed. Depending on the room and placement you will still get some irregularities in this area, but typically less than a conventional speaker. It's pretty much a given just by looking at the anechoic measurements / polar plots, as the reduced energy to the sides and rear will give less energy to the reflections that contributes to the cancellations in this area.
Another interesting aspect is that the response is suprisingly similar across different rooms. This is also evident when listening.
Here is an example from different rooms (combined average og left+right measurements), showing both slope and +/-3dB window so it's easier to see how much it deviates. Smoothing is 1/12th on all of these. All are different rooms.
Manta in my room
Manta in another room
Saranna, measurement from a customer room:
And to show that it's not magic, here is Saranna with a customer who insisted on having the speakers almost 1 meter from the wall, then we still got some reduction in energy around 150-300hz, and this is pre-EQ measurement so also clearly a huge peak at 50hz, but that was easily tamed by EQ. And beyond that still quite tidy:
No EQ above 100hz in any of these measurements.
So what? There is one bass drum in a concert, one organ in a church and record are mixed taking in account mono.which usually implies mono bass
While I agree with you on DBA there are recordings with two drum sets playing.So what? There is one bass drum in a concert, one organ in a church and record are mixed taking in account mono.
When length of low frequency approach the room size, we heard the room not the source.
Our brain is literally integrating the comportement of bass in closed space. Why loose our time with a chimeric stereo bass. Building a double bass array to address decay time is IMHO a greater priority.
Is that compensated for in recordings or are we all listening to a 60 Hz dip when we listen to stereo?
Of course, if you do not care about stereo bass, then my comment does not apply to you.So what? There is one bass drum in a concert, one organ in a church and record are mixed taking in account mono.
Okay, so the confusion was on my end as I wasn't sure how the question about "room interaction" was intended or being interpreted (referring specifically to SBIR, room modes, both, or something else I was unaware of).I addressed the question I was asked, which was whether it would improve the ~80-400hz area, so the transition range that is often plagued by SBIR effects. The answer to that is yes.
We need to clarify "room-modes" and "SBIR" are two separate phenomena.Eh? This would seem to contradict the notion of EQing out room mode peaks below Schroeder, unless I'm misunderstanding you.
The problem is that the traveling wave analogy is not a good approximation below the transition frequency (Schroeder frequency). This is the modal region, where standing waves (room modes) may dominate sound propagation. The wavelengths of sound in this region is comparable to the dimensions of the room itself, which is why the location of subs is not relevant for sound localization - up to a point, of course. Things like imaging and sound stage is provided by the range of frequencies above the transition frequency. This is where coaxial drivers do their thing.My understanding is that a point source creates a single wave front that as it travels through air is inherently better in the time domain that seperated lobes like multiway speakers or separated subs. This is why coaxial drivers are so popular. All this stuff.is very subtle and trying to ABX colocated vs distributed for slam is more or less impossible. I can quick switch from IIR to Linear phase but it has a massive tell when going from IIR to linear phase so can't ABX blind but the switch is quick and they sound noticably different to me.
I agree with everything you say, but I believe «node» usually means low-pressure zone (nulls) and «antinode» means high-pressure zone.We need to clarify "room-modes" and "SBIR" are two separate phenomena.
SBIR are known as quarter wave nulls; where a bounce from a wall causes destructive interference by sending a wave back into the direct sound 180 degrees out of phase. These tend to happen in the region of 80-400Hz approximately. They can occur from back or side walls.
Modes are resonant frequencies of an enclosed acoustic space, where sound waves reflect between boundaries and reinforce themselves to create standing waves. This creates high-pressure zones (nodes) and low-pressure zones (antinodes) that remain stationary in space. This will occur when the wavelengths begin to correspond to the dimensions of the room. These will happen below the Shroeder frequency or sometimes called the transition frequency.
Most common modes are ;
Axial Modes(two walls): The strongest and most problematic; these occur between two parallel surfaces ( front and back walls).
Tangential Modes(four walls): Sound reflecting off four surfaces ( four walls).
Oblique Modes(six walls): Sound reflecting off all six surfaces (walls, floor, and ceiling). These are generally weaker due to energy loss at each reflection.
Sorry, and thank you for the correction.I agree with everything you say, but I believe «node» usually means low-pressure zone (nulls) and «antinode» means high-pressure zone.
OK but for bass/ mid bass I am trying to maximise the "impact" defined as dp/dt or another way the rate of pressure change at the LP. I believe it is settled science that a wave front from a point source has higher impact than a wave front from distributed sources. I also know the room messes up point source wave fronts but it also messes up distributed source wave fronts so it still makes sense that a point source wave front will have diminished but still greater impact than a distributed source wave front at the LP. Audibility is the hard part as ABX borders on impossible. I think my 2 "point source" system has better slam than when I had 4 subs but others report better slam with distributed subs, imagine thatThe problem is that the traveling wave analogy is not a good approximation below the transition frequency (Schroeder frequency). This is the modal region, where standing waves (room modes) may dominate sound propagation. The wavelengths of sound in this region is comparable to the dimensions of the room itself, which is why the location of subs is not relevant for sound localization - up to a point, of course. Things like imaging and sound stage is provided by the range of frequencies above the transition frequency. This is where coaxial drivers do their thing.
Agreed, Psychoacoustic smoothing can be very helpful for deciding what to worry about and what to leave alone.Another option is deciding which nulls and SBIR cancellations are actually tolerable within the constraints you are working with, such as placement limitations or lack of access to systems like Dirac ART. If a null is outside the crossover region, relatively mild, or the SBIR cancellation is narrow and well-controlled, it may be preferable to accept it.
Indeed. I'm a sorry fool with just one measly subwoofer on the front wall (though I do at least have Dirac). There's definitely a null in there, but I have only noticed it in two circumstances: tooling through the bass region with a tone generator, and on one particular electronic song which has a descending bass note that happens to hit the null. Otherwise, it's completely unnoticeable. I could spend a lot of time, effort, and money adding a sub or three and integrating them to address it... or just leave it well enough alone since it's really a non-issue 99.99% of the time.Another option is deciding which nulls and SBIR cancellations are actually tolerable within the constraints you are working with, such as placement limitations or lack of access to systems like Dirac ART. If a null is outside the crossover region, relatively mild, or the SBIR cancellation is narrow and well-controlled, it may be preferable to accept it.
