It will reduce sound quality, but its effects are probably inaudible and thus negligible if they can only be heard within 10cm of the driver with all volumes set to listening levels without any music playing. Sounds like it's even softer than the likes of the JBL LSR speakers' hissing, probably only a few dB, and in a relatively insensitive region of the frequency spectrum too. Unless higher order harmonics get out of hand, I don't think it should be an issue. I'm rather inexperienced and new to audio science though, so take this with a grain of saltThis is very interesting since I have a NAD T187 that introduced a low humming noise in all of my speakers. The T187 is upgraded with 4K and atmos/ Dirac modules. It’s connected to a Emotiva XPA-3 GEN 3 and a Parasound 5125.
The hum (50 hz since I live in Sweden) is very low and can only be heard from about 5-10 cm from the midrange. (Yes the hum is heard mostly from the midrange, not the bass drivers).
Can hum reduce sound quality even when it’s low and only heard from so close to the speakers?
I’ve tried everything is can think of, I have dc blocker on the mains and everything is powered from the same outlet. Tried other outlets, tried rca-xlx cables, tried IFi gnd etc. The building is only 5 years old.
I did make a post about this on here as well.
If you have any ideas, I would gladly accept them!
Hi @amirm . I hope you can give me a comment here. I have 1 speaker connected to 1 mono power amp, silence. If i connect 1 rca to the amp i get a buzz. This is of course where i ended up with my root cause analyzis. Different rca´s tested different powercords tested. Amp is grounded.That is news to many people who have home theater AVRs with such connections and quite audible ground loops.
The answer was in the video and in Bill's presentation. Even though you have a double insulated device, there is capacitance between the chassis and the mains wiring that causes mains leakage and current to flow to the chassis of another device similarly situated but at different ground potential.
As I explained in the video, there is no such thing as a system with no ground loop. It exists by definition in any system using unbalanced connections. You get lucky that it is not audible vast amount of time. Not because it doesn't occur due to two-wire electrical connection.
What did you hook up to the RCA cable?Hi @amirm . I hope you can give me a comment here. I have 1 speaker connected to 1 mono power amp, silence. If i connect 1 rca to the amp i get a buzz. This is of course where i ended up with my root cause analyzis. Different rca´s tested different powercords tested. Amp is grounded.
Hi. Nothing. I get the sound when rca is connected to amp. Thank you.What did you hook up to the RCA cable?
I wonder if this creates what they call the antenna effect?Hi. Nothing. I get the sound when rca is connected to amp. Thank you.
Whent from TV blueray turntable ... disconnected everything in the system, of course lots of other equipment in other rooms not disconnected, and ended up here. This is the first connection when the sound appears. I have got two mono amplifiers and one 4 channel amplifier from same brand all of them get the noise Tested with 35y Sansui, no issues. Best regards Klint.Hi. Nothing. I get the sound when rca is connected to amp (D) Thank you.
Yes. Nothing else is attached.@Klint so your only attaching a RCA cable that's not conectet to anything? And you get noise?
Does not do so.The cable is acting as an antenna. This is completely unsurprising with an unbalanced cable on a sensitive high-impedance input, especially if the cable topology is nothing short of perfect (or there are other problems like a leaky shield). The noise should go away if you plug the cable into a source that is powered on, because a source will apply a low impedance across the cable, effectively shorting it and thus preventing EMI-induced voltages from appearing (up to a point, of course - but it's usually good enough).
Does not do so.
Speaker-Amp-RCA, amp powered up. No source, sound. Any source, sound. 3 different cable brands tested. In 2 of the brands I have double cables. 5 tested, same result.What is your source? Does the noise persist when connected to a known low-impedance source that is battery-powered and not connected to anything else (say, a smartphone jack output)? Also, what is the make and length of the cable?
This doesn't sound like any kind of grounding/power issue. It more sounds like a broken device in the chain.The problem is that I'm having terrible static and popping noises that are issuing from the speakers, especially during the loud passages in the music.
Thanks, Amir. I did have a fuse blow a couple days ago in the DAC, but I replaced it and it works fine with my PrimaLuna amp, but not my Pass Labs amp. And the Pass Labs amp will work with the RCA out from a basic CD player, but not from the Lampizator DAC, which causes a lot of noise.This doesn't sound like any kind of grounding/power issue. It more sounds like a broken device in the chain.
