- Thread Starter
- #41
It is pretty simple to approximate it if you don't include the window:No idea how to compute the FFT gain.
FFT Gain =10*LOG10N(N/2)
Where N = number of points. For 32768 points ("32K") it is 42 dB.
Spikes only occupy one bit or so as a result, they are not subject to FFT gain and can be read as is. I do this all the time in my analysis of FFT.And also, does the FFT gain affect just the bottom edge of the noise floor, or the noise peaks?
I also have a similar setup- an older QuantAsylum QA-400.
I usually run 32K points, and Hann windowing because.... actually I have no idea. Seems like a happy median setting. No idea how to compute the FFT gain. And also, does the FFT gain affect just the bottom edge of the noise floor, or the noise peaks? Maybe Matt from QuantAsylum can make some videos like this for his product? hint hint
I have to make an unsolicited and unaffiliated plug for him btw- it's a great product and tremendous value.
I change the FFT size depending on what I'm looking for. Usually start small as it gives a quicker response.
We could do the old one-two manoeuvre. I'll post a link to @amirm's video on QA's forum and you can reply asking for Matt to do some tutorials that follow on![]()
Yay, thanks! Your video made me dive deeper and understand. So thank you for the video!You got it 100%.![]()
Does the whole Audio Community work off the same AP parameters / calibration?
