I don't know what the fuss is here. My Kali sub is far from a powerful sub, so it makes sense to hear distortion when plugging its port and compensating for that with EQ.
Most likely it is the language barrier, there is not the least of "fuss" (negative, exaggerated exitement, anger) around.
It is only so that you start your thread with a complaint targeting the KH150, now it is about the Kali (6.2 type, not 6.5, correct?). And all the in betweens. You suspect that "underdamped" makes bad sound, and you see that feature in some graph but you also claim, that you can't hear it. And finally you ask for a solution.
Maybe I got it all wrong. In either case, what you see in the graph and address as "underdamped" is group delay that is with full mathematical rigor unavoidable. Because the universe exsists only for so long .. really .. there IS a low frequency cut-off, and that makes the group delay all for its own. There would be "DC", no cut-off that is, possible only if there is no limit in time, and here the big bang chimes in.**
I'm NOT making fun of you. I told you that the logical (!) cross connections of time, frequency and all are well understood, even for loudspeakers. That big bang of a theory, Thiele/Small'S namely, took place in the 60s of the last century.
In practical terms the problem is considered solved, at least by me. I personally equalize, using two subs, for a reasonable flat in-room response at a variety of listening positions. That was it, because I take care of the excursion limits and power hunger of the devices. To design such a solution needs a littel bit of expertise, admitted, but only so little. The optimal starting point would be to engage the contemporary simulation tools, maybe under assistance by the DIY board here. To speculate about "underdamped" is not as promising, since we have that "Thiele/Small" complex around.
**You may "correct" for the group delay in bass, but that is only possible if you delay all the other frequencies as much; you essentially worsen the other, but not correct the group delay in the bass.
