Unbiased Perspective Please - AT-LP5X + AT-VM95EN + AT-PEQ30 to Sonos Fives w/ Sub
Sorry, misread. This is from the phone app's accelerometer measurement, with the ideal target being a perfect sine wave following the rotation of the platter.
The ideal is stable straight line at 33.333333 RPM. Not a sine wave.
Here's a comparison I just did of my Pro-Ject Debut Carbon EVO ($600, though my version with walnut finish and acrylic platter runs a bit more) and my Technics SL-1200MK7 ($1100):
This was the best I could get out of the Pro-Ject over 4 runs. The Technics by comparison was the same every time.
What app are you using?
Not really. One revolution at 33.33RPM is 1.8s = 0.555Hz.
Doh! I was in bed with my phone about turn off the light after watching a bit more of Netflix The Decameron figuring out the period and frequency from the graph in my head and thinking, "if it were eccentricity then it would be nearly 2 Hz." Good thing I didn't go into accounting.
Sonos person here. I don’t have any Sonos speakers in main listening areas, but I have two Ports and thinking about a third.
If money isn’t tight, get a Port as your distribution hub.
I’m actually looking at the Sonos Amp (I have a 30% off coupon) paired with a set of KEF Q350s (when they’re on sale again) once I have 1k$ burning a hole in my pocket (which I don’t have at the moment). However, I have a worry bead. The Amp did fairly well as a streamer when tested here on ASR, but it did not fare as well as an analog source (which I’d need for my TT)… So I’m on the fence.
I'm spending less time in phono-focused forums in the last year or two, in part because seemingly every thread gets infested by Technics honks who cannot fathom that others might not want a Technics turntable. Two things that are particularly notable about the endless stream of Technics fluffing and seeming bullying:
1) DD speed is great, a solved problem decades ago. It's absurdly beyond audibility and has been for decades. Does every thread on turntables need multiple posts yammering about DD? Uh, nope. Also, whether a well-executed belt drive also performs beyond audibility never matters to the honks. It's a constant stream of belt-drive battering. Tiresome.
2) The Technics honks almost never bring up the tonearm on these things. As great as DD can be, the Technics tonearms is an average performer. I'll take a Rega arm all day every day over the clunkers installed on Technics decks.
Last, it's absurd to place such weight on microscopically tiny specs on ANY turntable considering the medium, which is almost always non-flat, poorly centered, offering inherently high noise floor, etc. The best thing you can say about vinyl is that it sounds surprisingly good considering the ancient cave man technology involved. To argue one needs .025% W&F to convincingly portray music is ridiculous.
Bottom line is that if you are deeply worried about W&F being .025% vs .1%, you'd be far better off eschewing vinyl at all.
As always, the hard questions
In what regard a Technics arm is an 'average performer'? What exactly makes you prefer Rega arms?
Hmm. I dumped a TriPlanar in favor of EPA-100 and 500. Honk honk.
What’s the thing with the TriPlanar arms? They look different but is that it?
Technics honks aka informed people :)
All the bull**** marketing European belt drives brands made on 70s and 80s against Technics was the origin of (still) actual disinformed opinions.
As an example, real measurements shows that the Rega integrated headshell is worst than a decent separated headshell. Or you can try to walk in a wood floor with a Rega and a Technics TT playing.
Ok, that's honking (???), but is the same with tubes, amplifiers ... even with the media itself. Many times, distortion sounds "better", so that Rega tts sounds more "organic/warm/natural" and all the audiophile dictionary.
I prefer Technics because is one of the more precise devices to play records, at any price level, from the 1200s to the incredible sp10 or the new sp1000.
That's interesting and counterintuitive from an engineering point of view. Can you point me to the source?
Yeah, I buy nothing you just said. Technics is still outfitting their new and VERY expensive machines with bog-standard blunt-force tonearms. Too many of their models come (standard!) with wonky poorly cast/machined/finished strobe dots that make it appear the platter wobbles.
I arrive at the forums without an "agenda" when it comes to belt-drive or DD, manufacturers, etc. Then, I see thread after thread with the usual posters endlessly honking about Technics, Technics, Technics and unfairly castigating other makers, often Rega. It gets ridiculous and your statement above about headshells is clearly a ridiculous statement.
It isn't my statement ... and is ridiculous why? Because YOU (or what Rega marketing) say it?
It is that? Then open your mind with the real data I sended or show me your data. That's all, without personification.
That's science my friend, I have zero interest to a "headshell war" ... I need the time to listen to my technics tts ... LOL
Um yeah, you provided nor sended zero data, but apparently whatever you're asserting is "science my friend" so there's that.
To you I say...uh huh.
The measurements are zero data?
And your data is "uh uh"? ...
Enjoy your Rega and be happy, it's the only important thing.
