Unbalanced connections to active speakers?
roog
UK, Keynsham
I am considering a change to active speakers, I am likely to retain my current system which will mean driving my speakers via unbalanced line level feeds.
Having always kept my unbalanced cables short, I was wondering if there was a practical limit to their length before the signal is noticeably affected?
As long as you aren't wiring from room-to-room, or between buildings, I'd consider that a "short" connection and you'll usually be fine.
And if your speakers have a balanced input, the correct unbalanced-to-balanced adapter retains most of the benefits of a fully-balanced connection.
(it doesn't always work the other way around... A balanced-output to an unbalanced input is trickier.)
Mine are unlikely to be longer than 3metres or 10ft so from what you say it sounds like I should be OK
Actually you could run 1000 foot unbalanced RCA interconnects to a battery powered receiver, with only small level and high frequency response loses.
Often with long interconnect cable runs, the components on each end are powered from different AC circuits. This can result in higher Common Impedance Coupling Noise (power line related hum/buzz). So use coax cables with a heavy braided shield.
If the cables are coaxial and impedance matching is maintained at both ends of the line.
You may still want to post a rundown of your current system and everything connected to it. It may prove advantageous to use RCA to XLR cables with an integrated R||C on the shield connection.
I'm talking about characteristic termination impedance, not about ohmic impedance of the input/output stages.
Characteristic impedance matching is a transmission line topic, which is not a thing at audio frequencies (as stated in the article you linked). Analogue interconnects are not impedance matched - and don't need to be.
It only becomes an issue when cable length becomes a significant proportion of the electrical wavelength. The electrical wavelength of 20kHz is in excess of 14 kilometers. Unless your cable length is in excess of a couple of miles or so, you don't need to think about transmission line effects for audio.
IME that depends on the system, and level of ground noise. I've experienced ground loop noise with interconnect in the 1 to 2 meter region when a PC is in the mix.
And even with digital interconnect cables, the 75 Ohm Radio Frequency Characteristic Impedance cables.
The 75 Ohms only matters with long cables (say 30 feet/10 meters or longer).
Yes, you are right. Somehow I overlooked this ;)
I will note that the bigger concern is not EMI but rather ground loop induced noise.
Well there are audiophiles using unshielded unbalanced interconnects.
And braided shields are much better than foil shields at the problematic interference frequencies.
braided shields for interference below 10 megahertz
foil shields for interference above 50 megahertz
either between 10 and 50 megahertz
