No_hair_left
- Joined
- Nov 2, 2023
- Messages
- 203
- Likes
- 75
PIcked up a used umik 1 yesterday but it just wont read properly with rew, I downloaded the calibration files. The spl meter shows 50db in C weighted and 36 in A weighted. Problem is it wont go below those numbers even if I move the mic and cover it and I know my noise floor is actually 26-27db as thats what it was reading on the xtz pro mic and decibel x. It's a short usb cable too.
If I check levels before measurement in the measurements tab it will say 69db with -55.7dbfs with the avr set at -45 which is way off, when it should be 45db. If I move it to under -50dbfs which is about -30 on my avr then it will show 85db reading which again is way off given I only have arendal 1961 speakers which are 4ohms.
I made sure the mic input in windows is set to 0db, turned off enhancements, enabled mic access, I had 0 problems with my old xtz mic which read everything correctly.
What is going on here?
I have spent a fair amount of time looking through posts and possible solutions and nothing seems to work it's very odd. Even just comparing it to my phones decibel x app which was near on spot on with my old xtz pro mic it's showing nearly 20db off in some scenarios.
Looking at the calibration file it has a sens factor -2.258db if that means anything. I'm sure I must be doing something wrong but I am out of options.
