Hi everyone,
I have a miniDSP UMIK-1 that I normally use to tune the audio system in my car. I recently decided to buy a Dayton Audio EMM-6 as well, mainly because I wanted to measure time delays more accurately using a loopback timing reference, which I couldn't do with the UMIK-1 since it is a USB microphone.
Since I now had both microphones available, I decided to compare them, but the results were somewhat puzzling.
I placed both microphones in exactly the same position, with the capsule about 15 cm from a small full-range speaker, and performed standard logarithmic sweep measurements in REW.
For each microphone I took two measurements:
Green: EMM-6 with its calibration file
Orange: UMIK-1 with its calibration file
Purple: raw EMM-6
Blue: raw UMIK-1
What surprised me is that the raw responses of the two microphones are actually quite similar in several areas, but after applying their respective calibration files the differences become considerably larger.
In particular, around 450 Hz and 700 Hz there are differences of approximately 2 to 2.5 dB between the calibrated measurements. Above roughly 3 kHz there are also differences that reach about 1.5 dB.
I also performed a loopback measurement of the Behringer UMC204HD used with the EMM-6, and its frequency response is essentially flat, so the audio interface does not seem to explain these discrepancies.
These are fairly substantial differences for microphones that are both supposed to be individually calibrated, especially since differences of 1 to 2 dB in these regions could meaningfully affect an EQ calibration.
So my question is: which microphone/calibration should I trust?
I’m also considering sending both microphones to a specialized calibration laboratory for an independent calibration, but before doing that I’d be interested to hear what you think about these results.
- a raw measurement, with no calibration file loaded
- a calibrated measurement, using the manufacturer-provided 0-degree calibration file for that specific microphone
Purple: raw EMM-6
Blue: raw UMIK-1
