Blumlein 88
- Joined
- Feb 23, 2016
- Messages
- 23,571
- Likes
- 44,671
You can always use your Umik 1 to calibrate the ECM8000. Not very hard to do.
I don't know what you're comparing or what's "drifting" but I'm seeing 77.6 us = 0.027 meters (27mm) or 1.05 inches at the speed of sound. The microphone (or microphone element) might be in a slightly different position?The drifting is within ~0,027 ms range.
It doesn't seem significant when you consider the varying location of your ears and the distance between your ears.
And what do Dirac Live's algorithms with the deviations, for example?It doesn't seem significant when you consider the varying location of your ears and the distance between your ears.
