Umami Audio Perfect Soup MIMO
Interesting comment.
Are you suggesting that Dirac Live in all of it's forms (DL, BM, BC, ART) has a bad rep?
And if so, could some of that be attributed to USB microphones?
There does seem to be a lot of Dirac Live users using UMIK-1 or UMIK-2.
This has changed and now we support USB mics if you want to check it out!
Along with a ton of other new stuff in this release:
New in this release – Calibration loader​
  • Linux support. For the first time, Perfect Soup runs on Linux
  • GPU processing engine. Process the audio on your GPU or iGPU!
  • Snapshots. Save up to 16 setups of calibration, EQ and level, recall them in one click. Automate them from your DAW, and export or import them.
  • CLAP and LV2 on Windows and Mac.
  • Sync all Calibration Loader instances. One switch links every loader on the computer, even across different DAWs, so calibration, volume, dim, mute, bypass, EQ, gain limit and the active snapshot match everywhere. Hosts that sandbox plugins may not be able to join.
  • Fixed IO versions. Umami Calibration Loader 16x16, 32x32 and 64x64 have a fixed set of 8, 16 or 32 stereo inputs and outputs.
  • Lighter projects that keep their calibration. A project now saves a reference to its calibration instead of a full copy.
  • Live spectrum analyzer. A per-channel spectrum display sits behind the EQ graph, switchable between input and output.
  • Three license modes. USB dongle (full offline), Standard and Tethered. Standard keeps working offline for up to 7 days with a limited number of "instant recoveries." Tethered allows unlimited swapping between computers, but every computer must stay online.
  • Headphone generic profiles
New in this release – Calibration Wizard​
  • Smarter multi-take measurement. Bad takes are automatically detected and retaken
  • Guided mic placement. A map shows where to put the microphone next: the center seat, then the edges of the seating area, then filling the gaps. A readout shows how many positions your seating area needs and how many you have measured.
  • Separate input and output interfaces, and USB microphones are now supported.
  • Measurements are not lost if the wizard closes. If the wizard closes before a measurement is saved, it offers to finish uploading and saving it the next time it starts. Measurement details also save to your account as you go.
  • Live mic locate. Once a listening position has been measured, locating the microphone sets each main speaker's locate level automatically.
  • Support for offline measurements. Measure on one computer then upload it on another
Other new stuff​
  • Perfect Soup Desktop. Third-party system audio host no longer needed.
  • Umami Knob controller support. Available for purchase soon
  • USB-key licenses.
Interesting but I'm not a fan of monthly recurring fee. The outright buying option for $1k with lifetime upgrades is very cool but I feel the price is a bit steep. However, it has a 1 year calibration access period, what does that mean?
Please don't take offence, I am merely expressing my thoughts and opinion. If the outright ownership cost would be sitting at about $500 to $600 then that would make it attractive based on how well it performs.
I presume Perfect Soup now runs as a standalone app. From what I understand it runs on a computer (Laptop). Once all the measurements are done and Perfect Soup generates a room eq profile, where is it uploaded to? Does one need a multichannel DSP between the processor and power amps?
It's not a monthly or recurring subscription. Calibration Access only needs to be renewed when it expires and you would like to create new calibrations. Any calibrations you've already generated remain available for use indefinitely. For the software itself you get free lifetime upgrades. We'll also offer free calibration updates should compatibility issues arise from software updates.
We also offer more affordable licensing tiers, allowing you to choose the option that best suits your system and output requirements.
We continuously refine and improve our calibration algorithms. Whenever a new algorithm is released, you can queue an update to your existing calibration and receive the improved version directly through the Calibration Loader with a single click. If desired, you can just as easily revert to a previous version. Before releasing an update, we run the new algorithms against our existing measurement database to verify that they deliver measurable improvements across the entire database, while also carefully investigating edge cases.
Measurement data is uploaded securely to our servers, where the filters are calculated and then returned to the Calibration Loader. At present, our software is supported on Windows, macOS, and Linux and runs exclusively on desktop and laptop computers.
I hope you'll decide to at least check it out! Our trial is 60 days so you can really test it thoroughly.
So how can it be integrated in a multi-channel dolby atmos configuration? - I notice that the OP has managed to do it. So once the filters are calculated it is uploaded within the software running on a Mac OS or Windows computer? Just trying to understand the integration part for a DA configuration with separates.
D-ART corrects up to about 150Hz, is PS the same? Also, in a 4x4 DBA setup is PS designed to take control of every sub and does it optimise the use of all the sub drivers or does it resort to a 50-50 approach which halves the overall output? I think Trinnov's WF has the ability to toggle between emit and support in real time.
I run PS on a dedicated Dante connected DSP server. The full signal chain is SW42DA-V2 --Dante--> DSP --Dante--> Lynx Aurora (n) --AES/analog--> speakers (5.2.2).
If you're running analog separates, you can substitute the Dante interfaces for any multi-channel audio interface with ASIO/Core audio/ALSA drivers. The interface (and PS) would sit between your AVR/signal source and the amplifier(s).
On my latency optimized setup PS's added latency is 10.8 msec, 10 ms of which is due to the filters themselves, so it's very usable for gaming and other applications where latency matters.
The filter sets (calibrations) are stored locally on your computer and the newest version can run fully offline.
The cutoff is currently set to ~160Hz but it's on our road map to set this individually and automatically based on measurement data. Perfect Soup is designed to take control of each sub individually and the algorithm automatically decides what the power distribution between each sub should be.
I should also mention that the new desktop app and Linux compatibility make it very easy to build a dedicated room correction processor. I’m running PS on a stripped down Debian system, with the desktop app running as a kiosk-style application in Cage WM. Audio threads can now be pinned to isolated cores (a feature Umami kindly added at my request), so performance remains rock solid even at very low buffer sizes. I'm running 32 sample buffers @ 96 kHz with zero xruns and there's still some performance headroom left.
Thank you for that information. Glad to learn that that PS takes controls each sub. You mentioned that it automatically decides power distribution between subs, can you elaborate on this for further clarity.
This is really interesting, what stripped down Debian system are you using.
What interface are you using?
I can't give you too much details actually, grandma's recipes are family secrets (plus they're always changing because we're always building, tuning, and improving). But I will say we try to take everything an expert human would into consideration, augmented by a lot of compute power :)
@umamiaudio - I totally understand and respect that, I am not asking for the recipe. What I am asking for is how the signature dish tastes and the size of the portion served :).
In other words, when you have multiple subs, the minimum default total power that your distribution algo would provide, assuming we are talking about subs only, is 50%. How much more can we get up and above 50% without compromising the ingredients?
minimum default total power that your distribution algo would provide <== there is no minimum. We mostly don't set thresholds like that. It's all measurement dependent so nothing can really be said without measurements and also it will look different in every room.
It's a fairly vanilla minimal Debian 13 installation with only the bare essentials needed to run PS installed. The whole installation, with 100s of megabytes of calibrations, is less than 4 gb. The major modifications to a completely vanilla installation are:
- a RT patched kernel
- boot parameters to isolate a number of cores from regular thread scheduling for PS's latency sensitive audio threads
- Manual IRQ affinity tuning to move the interface's interrupts to a dedicated core
- manual thread affinity assignment for PS's UI and audio threads
The PC hardware is a dedicated Intel 270K Plus based server with a Dante PCIeR card. The CPU is overkill for the application.
If you're interested in building something similar, I'm happy to help and share my config files
I gave Umami a first try today.
The wizard is very comprehensive and guides well through the measurement preparation process. I set the headroom to 30dB (pre-set standard value).
When doing the first measuring step (tweeter nearfield measurement) of the left speaker, the sweeps were quite silent. Then suddenly there was a scary loud (!) sweep of the right tweeter. I aborted the measurement immediately.
@umamiaudio is this behaviour intended? If yes, how should I set the headroom to avoid a tweeter damage?
I'm still tweaking the whole process so any feedback is greatly appreciated. In the upcoming updates there's going to be a whole different procedure that's even more clear on how to set things up, but for now, the headroom setting basically sets the amount of headroom your system has, which should be a level that your system can safely sustain. -30dB means there's ~-30dBFS of headroom and it expects that your system should be able to handle that.
What it does during the nearfield sweep is that after sweeping the first speaker, for the next speaker, it sets the gain automatically (within a limited range) such that there is roughly equal SNR, so the behavior is intended. I'm just pushing a new version now (Win 434 / Mac 388 / Linux 49) that has a bunch of fixes, but I'll add a feature in the next release that allows you to limit this behavior or turn it off completely. (this is a small update, so I think you can expect it in a day or two)
For now, the best thing to do is probably to turn down the gain of your speakers for the nearfields measurement then turn it up for when you want to do the listening position measurements (at which point it shouldn't be changed anymore because the system relies on the speakers having an exact gain).
Okay, very important information!
Will give it a new try tomorrow and limit max. volume of near field sweeps to a save level.
[horror emojis]
Just as a general comment, DSP related testing tools are famous for physically destroying speakers.
I'm hoping to have physical limiters downstream to ensure this does not happen, my speakers cost more than my 6mo of my whole family's living expenses budget
Couldn't a feature be implemented for noobs to initially run a "max safe SPL" test and that hard-codes a "not to exceed" reference point for all subsequent testing?
maybe with saved profiles if the software might be used on multiple systems, in different locations etc
[horror emojis]
Yeah, the scary thing here is @markstein is not a newbie and very experienced at measuring speakers.
Why was there a level difference between measuring the left and right tweeters?
I did not observe a significant level difference between speakers when doing the near field measurements. I did have headroom set to -50 dB though, which was already a bit uncomfortably loud
Thank you.
I guess the huge level difference was due to:
- very nearfield measurement of left tweeter inside the waveguide
- distance to the right speaker approx. 2.8m meter
- controlled directivity due to waveguide, i.e. relatively little energy from the right speaker arriving at the mic in front of the left speaker
I was surprised not to have understood the "auto levelling" behaviour correctly as this goes against intuition and experience with Dirac and REW where you set a max. level not to be exceeded.
Imagine someone with a compression tweeter inside a horn does this calibration without being aware!
