Stingber09
- Joined
- Jun 24, 2022
- Messages
- 19
- Likes
- 33
Hi, I decided to make a separate post for my results using Umami Audio Perfect Soup Room Correction Software. I tested it with a 9.8.6 Atmos System.
I never heard my room as cohesive and clear. Bass was precise and tight. Below you will find my before and after measurements.
I plan to add a block diagram of the hardware used.
Umami Audio: https://umamiaudio.com/how-it-works/
System Calibrated:
System Uncalibrated:
System Calibrated with LFE:
System uncalibrated with subs:
Room Layout:
Left Front speaker Calibrated Decay Time:
LFE subs calibrated Decay Time:
Speech Transmission Index (STI) Analysis:
Umami Audio VST Plugin:
System Calibrated:
Room Layout:
