Mic arrived today a day early from Hong Kong, and no import duties collected - bonus.
I initially started a thread here
https://www.audiosciencereview.com/forum/index.php?threads/planning-room-eq-like-this.26409/
for some up front advice (thanks to everyone who helped), but have since realised it was the wrong sub forum, so I'm starting a new thread here.
(If anyone wants to move the previous thread, feel free)
So in the other thread moving mic measurement was suggested and I would like to give it a try. However, I'm getting significantly different SPL levels from the moving mike method compared with the sweep measurement.
I've added the cal file for the UMIK-1. I've set an SPL of about 75 with pink noise from the generator.
I've carried out a sweep measurement, then a capture from the real time analyser - which I believe is what is used for a moving mic measurement from the video linked in the other thread. However, the video didn't give any info on setting up the measurement. Settings and Mic position are unchanged between the two measurements.
In the screenshot, the green line is the curve from the sweep measurement, and the red curve is from the real time analyser. As can be seen the sweep gives a much higher level (and closer to the 75dB set up in the SPmeter). The RTA curve is very similar in shape, but about 20 to 25 dB lower, and with the higher frequencies falling off more.
Any ideas what I may have wrong in (I'm assuming) the RTA measurement?
Thanks.
Thanks.
