Ultra low THD class D amp project.
Hayk
The main element of this project, to start this year, is the TAS5631B. This chip is PWM input with 80db analog NFB that makes it enough low distortion to function in open loop with TAS5518, digital to 8xPWM.
I will use this power stage in BD modulation and with 60db analog post filter feedback.
I designed the PCB of the 5631B to start trials. I added a pair of Schottky diodes on each outputs for lower temperature, modified the suggested PCB as it doesn't have the output filters and mounted the 5631 on the bottom side to be cooled by the chassis and external heatsink.
The triangle generator and the PWM comparator are simulated as shown below as well as the input interface. The opamps will be opa1656 or 1612.
The THD will probably be limited by the opamps.
I am advancing with this project slowly but surely. The PCB of the power stage is here, needs some modifications. It is application circuit with Schottky diodes added optional to reduce the heat dissipation. The output filter is the same as I used for tpa3255 BD modulation. What is new, the input stage that feeds the comparators is a seperate add-on board to choose chip opamp or discreet, maybe tube hybrid.
The discreet opamp I designed is a 2 stage with low noise jfet k209, smd of k117, in LTP and an odd VAS originally from AKAI amplifier. On simulator for unity gain, it has 0.00015% THD and 100Mhz bandwidth. A pair is needed for each channel.
Besides precision triangle generator, it has soft clipper using the CLIP signal from the TAS to allow maximum output with minimum required pulse to charge the bootstrap capacitor.
This is the discreet error opamp applied in the PWM. It gets its input either from a phase spliter or directly in differential mode for ultra low THD, to be compared with the output PFFB.
The gain is adjusted by mutual resistor, 4k.
In case of single ended input, the amp is no more ultra low distortion, it will get stained with the phase spliter tube, 6j1 or transistors. For 2x2v output, corresponding 100w@8 ohm,the 6J1 tube, generates 0.3% THD and 0.01% lowest, using jfet bf247b. A bjt is 0.07%.
Two capacitors, 22pf, to be adjusted, determine the stability. It provides about 40db open loop gain to decrease the THD+N of TAS5631b of 0.005% by 100 fold. The stability will determine up to which frequency.
By lack of time and means, I chose the simple way to go.
I will leave it in differential input, single ended to be optional on an external board.
The TAS5631B, not shown, inserts between A,B,C,D inputs and OA,OB,OC,OD outputs.
I need to add some pf capacitors for the stability, note that it is full PFFB.
Sorry for image quality, the bluetooth of my pad got damaged, it is a camera pic.
Sorry fellows, I got banned from engineering discussions on this website, so this thread is discontinued. I'll post on DIY audio forum the gerber files when ready.
Per Amir,
