Given the choice between SMPS and a linear power supply, I’d always go SMPS.Is there a certain reason why you have to use that particular SMPS? Is it the most economical sure way to deliver clean power?
Out side of size/weight, any technical reason as to why not use a linear power supply?
All competently designed and implemented buffers should sound the same, or more precisely have no sound at all.Can anyone speak to whether the input buffers on the purifi modules actually much of a difference? I ask this question based on all the different offerings and because every NCore module I ever heard from different makers sound the exact same. Is it the same for Purifi?
Anyone shed some light?
https://www.audiosciencereview.com/...-opamp-review-sonic-imagery-vs-sparkos.10325/Can anyone speak to whether the input buffers on the purifi modules actually much of a difference? I ask this question based on all the different offerings and because every NCore module I ever heard from different makers sound the exact same. Is it the same for Purifi?
That has me intrigued and there is just no possible way that doesn't make some audible difference in my mind.
So in my mind shouldn't the input buffer with a Tube have a similar effect to the purifi modules?
I have no real experience with tube gear, but from what I understand, it all depends on the implementation. Both tubes and transistors can be implemented to add distortion, and both can also be implemented to mess as little as possible with the signal. I don't really understand what good tubes do in line level gear, other than giving something glowy to look at.
But I'm not judging. I just don't get the whole tube thing
Possibly. But why would you buy a product with Purifi modules, if you don't want the performance they are designed for? Why not just do it proper and get a tube power amp?
EDIT: Made me think of this thread: https://www.audiosciencereview.com/forum/index.php?threads/distortion-products-are-fish.15423/
For starters, I have space constraints and these amps tend to run small and cool by comparison to tubes.
If I could potentially get both an excellent SS design and a tube accent I might acheive audio nirvana.
A lot of the “audiophile cred” about linear power supplies is the bling associated with toroidal transformers. They are big, heavy, and look like they mean business. Funny thing is that in a linear power supply, a dinky cheap-looking split bobbin transformer would do a better job.
Granted, my opinions are informed by high-school level physics. I haven’t picked up a soldering iron in 30 years.
Any news or rumors about an upcoming high powered purifi module.
Chipageddon is making things difficult for everybody.Any news or rumors about an upcoming high powered purifi module.
I’m at camp linear PSU. kind of like.. the bigger the better
I do think linear PSUs are “superior” overall but are at a huge disadvantage for cost size and efficiency.
And yes the transformer is big key, bulky heavy full of copper and costs $$!!!
Also lots of big filtering capacitors... to eat up the noise and to get that clean smooth voltage.
I don't believe the list is still maintained
