Either one should do the job. NAD is cheaper and has a better case (that aluminium case of the Apollon looks quite similar to the Nord cases and those are flimsy cases at best). Also, the NAD has the 12 volt trigger by default. The Apollon on the other hand seems to have a dual powersupply while the two hypex modules in the NAD seem to share a single one.
I think I would go for the NAD. Full disclosure, I already own a C298, so I am problably biased.
I went to a different route by ordering the P452 from March Audio. Quality and design is really top-notch and price wise you will be very close to the NAD if even cheaper (Depending where you live)Either one should do the job. NAD is cheaper and has a better case (that aluminium case of the Apollon looks quite similar to the Nord cases and those are flimsy cases at best). Also, the NAD has the 12 volt trigger by default. The Apollon on the other hand seems to have a dual powersupply while the two hypex modules in the NAD seem to share a single one.
how does it sound?
I know purifi doesn't "need" two, but there are several implementations that involve two power supplies
so there must be a sonic difference.
According to Purifi, use of two power supplies is discouraged and will not result in any difference in sound quality.Also, can anyone confirm the differences between the units with the power supplies as opposed to the single? I know purifi doesn't "need" two, but there are several implementations that involve two power supplies so there must be a sonic difference. Can anyone confirm or deny?
It sounds great. It used it to power my left and right channels. It partners with a P451 which powers my center channel and a hypex-based amp (also from March Audio ) for the surrounds. All are associated with a Denon 4700 used in full preamp mode.how does it sound?
Thanks guys, appreciate the insight here...So what is the purpose of all the units that have two of the power supplies?
...dual PSUs and a couple of different discrete op-amps to choose from...
That was partly the reason (besides other differences) me asking about the measurements.
Does anyone know whether Amir plans to perform measurements of at least some of these Purify implementations?
Maybe not the case here with Class D, but everything else I've experienced that is the case.
The Purifi modules are designed to have a massive amount of negative feedback that makes them practically immune to PSU noise. The only thing you have to worry about is power, and one SMPS1200 is enough for two 1ET400A
I have an MSB Discrete DAC and there are clear differences between one and two power supplies to the DAC.
I assume that's a subjective impression and not something MSB has measured and made public?
Has anyone seen NADs implementation of Purifi?
