It wouldn't be the first time a cheap Chinese device is used as a backdoor...This makes me suspect that the app does more than simply configure a setting stored on the headphones, although I haven't established exactly how it works.
Most every Bluetooth headphone I own isolates LDAC and requires user intervention in the app to enable it. That is, it is off by default and requires app intervention on 1st use. So, the UGREEN is not unique.RE: LDAC You'd expect the headphones to negotiate the highest-quality supported codec automatically, or at least let you select it directly in the phone's Bluetooth settings, rather than making it dependent on the companion app. Pretty unintuitive, if you ask me.
I beg to differ. Most of the Bluetooth headphones and audio devices I own that support LDAC don't require a dedicated companion app to enable it. Once paired, LDAC can simply be selected or deselected through Android's native Bluetooth settings, without having to install or configure the manufacturer's app.Most every Bluetooth headphone I own isolates LDAC and requires user intervention in the app to enable it. That is, it is off by default and requires app intervention on 1st use. So, the UGREEN is not unique.
This makes sense to me. LDAC may provide the best sound quality when your Bluetooth connection is robust, but it provides the least stability when the connection is poor. In addition, it lowers the playtime because of its higher overhead and usually eliminates some features like multipoint connection and certain EQ/Spacial modes.
While it might be nice to have a dedicated LDAC button, my guess is most users are more likely to notice dropouts or the inability to connect to multiple devices, than will notice the sound difference. I expect LDAC Hi-Res labeling is something lots of people want when purchasing but that they do not use once the headphone is owned.
My error. On rechecking my Pixel 10 Pro is nearly unique in not supporting LDAC so the menu choices do not appear as they should. I do not know where they most often appear in the latest headphones on Android 17. I know there has been a move toward more integration with the apps rather than requiring users to go into Android submenus.I beg to differ. Most of the Bluetooth headphones and audio devices I own that support LDAC don't require a dedicated companion app to enable it. Once paired, LDAC can simply be selected or deselected through Android's native Bluetooth settings, without having to install or configure the manufacturer's app.
Just to give a few examples, I own the 1MORE SonoFlow, Sony WH-1000XM2....
I think you've misunderstood my original point. I never suggested that LDAC should be enabled by default. Quite the opposite: I explicitly acknowledged that it generally isn't, probably for good reasons relating to compatibility, connection stability and battery consumption.My error. On rechecking my Pixel 10 Pro is nearly unique in not supporting LDAC so the menu choices do not appear as they should. I do not know where they most often appear in the latest headphones on Android 17. I know there has been a move toward more integration with the apps rather than requiring users to go into Android submenus.
OTOH, my real beef with your post was the suggestion that LDAC should be on by default, which it appears you no longer insist on.
While installing an app may seem a hassle, not accessing LDAC seems to me to be among the tiniest problems faced by not installing one. For the UGREEN, You also cannot get firmware updates, adjust EQ and spatial settings, turn on/off game mode and multi-point.
UGREEN has one of the most rudimentary apps, with the least control. You lose a lot more options with most other brands. These features may not matter to you compared to app installation hassle, but I expect you are in the minority on that.
I've been using them for almost half a year now. My first bluetooth headphones ever (never thinking about this possibility, I even bought my LG V60 from Ali with the clear Intention of driving something wired), so I didn't know what to expect. With tuning they are pleasant, mostly indistinguishable from my AKG K371. ANC is helpful, no wind protection on the mics isn't.
They are constantly chipping away. The big break happened almost immediately, in a couple of weeks, on both of the ears. So I don't know how long they will live. Probably not long enough to justify the savings, but hey, I wear them 24/7. Literally.
Just to give a few examples, I own the 1MORE SonoFlow, Sony WH-1000XM2, HiBy W3, FiiO BTR7, FiiO JM21 and several others. None requires a companion app to activate LDAC.
For illustration, here's a screenshot of my SMSL DL200 connected to my phone, with LDAC selected and actively in use, entirely through Android's own Bluetooth settings.
Granted, LDAC isn't necessarily enabled by default, and for good reason. Manufacturers and Android often favour the more universally compatible codecs initially, since LDAC's higher bitrate can come at the expense of connection stability and battery life. The user may therefore need to enable it manually. But that's precisely the point: this can be done directly through Android's native Bluetooth settings.
With the UGREEN HiTune Max5c, however, I haven't found any way to enable LDAC without first installing the UGREEN Audio companion app. To make matters worse, the app repeatedly prompts you to sign in or create an account, which seems entirely unnecessary just to enable a standard Bluetooth codec.
Of course, manufacturers may use their companion apps to expose additional codec options or provide proprietary configuration features. But that's quite different from making the app a prerequisite for enabling LDAC itself. In my experience, LDAC activation is handled perfectly well by Android's native Bluetooth stack, provided both devices support the codec. That's precisely why I find UGREEN's approach somewhat unusual.
Thanks for this. I do have an update that to some degree contradicts your analysis.They work fine for me. Motorola Edge 60 Pro, Android 16, and no UGreen app installed:
For anyone here looking to apply Amir's parametric EQ settings (or any other Equalizer APO / Peace profile) system-wide on Android via Wavelet, I built a small, free browser-based converter that turns APO configurations directly into a 127-band GraphicEQ.txt file:
https://eqapo-to-wavelet.gapski.workers.dev/?lang=en
Since a few folks in this thread mentioned using UAPP or tinkering with EQ on their phones to fix the stock tuning of the Max5c, this makes it quick to bring desktop PEQ profiles over to Wavelet for streaming apps without messing with Python scripts.
A few quick details:
Just paste Amir's filter values in standard APO format, download the generated GraphicEQ.txt, and import it in Wavelet (AutoEQ → GraphicEQ → Import).
- Runs 100% locally in your browser: Nothing is uploaded to a server.
- Format support: Accepts config.txt, peace.txt, or ParametricEQ.txt (file upload or direct text paste).
- Frequency response preview: Plots the original PEQ curve against the smoothed 127-band Wavelet output so you can verify the fit before exporting.
- Sample rate & preamp: Lets you select the target sample rate (44.1 / 48 / 96 / 192 kHz) and auto-normalizes the output to −0.1 dB to prevent digital clipping.
- Open source & zero dependencies.
Hopefully, some of you find it useful for dialing in the Max5c!
