Most speaker surrounds are black rubber, which uses carbon black. This should give them almost perfect protection from UV.
The problem seems more likely the IR component of sunlight heating the rubber up.
But have you seen the thread of Salon 2 owners, where the surrounds have fallen apart? What could be the cause here?
https://www.audiosciencereview.com/.../parts-for-salon-2s.39191/page-6#post-2434076 The carbon black would shield them from UV and the user doesn't even leave them in the sun. Butyl rubber is waterproof so it can't be the humidity.
If loudspeakers are exposed to sunlight—for instance, every day—the surface hardens due to UV light and becomes brittle (though this is often visible only under high magnification). This damage is then exacerbated by the movement of the driver. Most people are unaware of these long-term effects. Moreover, it makes no difference whether the ambient temperature is warm or cold. Depending on the geographical region, this can amount to anywhere between 10,000 and 20,000 hours of sun exposure over a ten-year period.
The issue observed with the Salon 2 speakers appears to be the result of severe overloading, improper sizing of the surround—or perhaps a combination of both.
I have frequently encountered this type of damage when loudspeakers are used for watching movies—specifically without a subwoofer and without limiting the low-frequency output directed to the main speakers.
While owners often claim they did not overload the speakers, this is simply because they failed to notice when it was happening.
In many films—particularly action movies and those featuring loud, orchestral scores—the low-frequency content is often many times more intense than that found in standard music recordings.
With standard music, you can usually tell immediately when the speakers are reaching their limits; with movies, however, you typically cannot—something I have personally verified through experimentation.
The typical signs of overload damage in such cases include damage and cracks in the cone itself, right where it meets the rubber surround (there are some interesting images illustrating this on KEF’s aluminum cones, where the cones can literally shatter or tear apart); cracks along the inner fold of the rubber surround, right at the junction with the cone; and cracks along the outer fold of the rubber surround, where it joins the driver frame.
